June 20, 2013, 09:32:01 am *
Pages: 1 [2]   Go Down
Author Topic: big gears  (Read 2611 times)
Hydrargyrum
member.GetText(Hydrargyrum);
« Reply #25 on: July 31, 2007, 02:17:39 am »
As they've said, the weight would make them a good base for something; At the same time, the weight would make it something that's very difficult to move, and could easily damage any kind of surfaced floor (Linoleum, wood, etc). Given that it's already rusted and looks old, perhaps an outdoor function would better suit it? Lamppost base, mailbox base... Think bases, as I don't think you're going to want to right anything with 100 pounds atop it more than a foot or so off the ground unless there's no possible way of it tipping, sliding, or falling over and injuring someone.
Nothing you can make that can't be made...
Zaxton Books
« Reply #26 on: July 31, 2007, 02:45:26 am »
If you had some sort of adamantium shelves, you could use them for bookends.
Or, as an alternative, plane them down and mount them to your car as hubcaps. Better, cut two in half and do the same.
Sir Theodore Catchpole
« Reply #27 on: July 31, 2007, 05:05:07 am »
i think with gas as it is here that would not be a very good idea
maybe use it as a base for something like this.
only a little more steampunk then that
Knox Motor Company
Dedicated to building simple, fun, fast, rugged, vehicles.
http://knoxmotors.webs.com
Hydrargyrum
« Reply #28 on: July 31, 2007, 08:22:00 am »
That's what I was saying. Something like that for a lamppost. If, in fact, you could cut them in half, I'd say do so, and make twice the number of bases; Even 25 lbs of base should support that with no issues, and there's no need to hide half the gear by having it face the ground.
« Reply #29 on: July 31, 2007, 08:26:59 am »
i do not think that i have any of the tools to do that so i think that i will just leave the as it.
but if i did want to how would i do it?
Hydrargyrum
« Reply #30 on: July 31, 2007, 08:33:32 am »
That really depends on what sort of light you're hoping for. Some sort of gaslight lamp would be astounding; A propane tank at the base, with the properly insulated piping, to some sort of Victorian or Victorian-style lamp? Another option is... You said you had three or four? Perhaps a set of clockwork-themed lawn chairs are in order?
« Reply #31 on: July 31, 2007, 05:51:33 pm »
i have 3 of them
Pages: 1 [2]   Go Up
Page created in 0.347 seconds with 19 queries.
