February 10, 2012, 12:23:09 am *
Pages: 1 ... 101 102 103 104 105 106 107 [108] 109 110 111 112 113 114 115 ... 150   Go Down
Author Topic: A Collective Thread for All Them Guns  (Read 270365 times)
Sir Robert
« Reply #2675 on: March 19, 2010, 04:07:08 am »
I hate to spoil the fun but do not play with high powered lasers you will shoot your eye out, pun intended.
These suckers are more than capable of causing for real permanent blindness!
Not toys!
Sir Robert, Soldier, Gentleman Adventurer, all around nice guy.
Laserpunk
Rogue Laser Enthusiast
« Reply #2676 on: March 19, 2010, 07:07:03 am »
Does anyone have a good idea on how to find good, cheap leather?
I'm trying to make holsters for my steampunked NERF Maverick REV-6 and double-barrel shotgun props.
Pictures, suggestions, instructions, and tips would be of help also.
Thank you
Salvation Army, thrift stores, Craigslist, junk piles. Use you imagination. Many things are made of leather. Purses, boots, coats, belts, couches, ect. You can always dye it, just try to find something light, and brownish.
Not toys!
Defiantly. Nothing is worth the price of your site. Anything over 5mW and you should have goggles.
Look for the OD (optical density) rating. The higher the OD the more the protection. Also you need the correct goggles.
532nm is green
635-650nm is read
405nm is Blu-Ray
808nm is IR
IR is the most dangerous because you cant see the beam, and you wont know you are blinded till its too late.
« Last Edit: March 19, 2010, 07:15:42 am by Laserpunk » Logged
Don't be proud of something you bought, be proud of something you built.
Companies I personally endorse for lasers, and accessories. Don't get ripped off on eBay.
www.O-like.com www.rayfoss.com www.dragonlasers.com www.optotronics.com
For parts, diodes and modules http://www.modwerx.com/
Angus A Fitziron
« Reply #2677 on: March 19, 2010, 11:03:41 pm »
re last post, I am sure Laserpunk meant that anything with a wavelength longer than 800nm is in the infra red - most communications lasers are for example 1300nm. The problem with IR lasers is that the eye blink response fails because infra red is beyond the visible spectrum, but still enters the eyball causing retinal scars and if you are really unlucky damage to the optic nerve. The damage is not just a function of power but distance comes into it as well. It is best to wear goggles (at last a genuine excuse) even if using sub 5mW devices as they can overpower briefly if the feedback circuit fails. Of course the laser burns out immediately after but would you want to take the risk of looking down the barrel when it happens?
Laserpunk
« Reply #2678 on: March 19, 2010, 11:36:40 pm »
You are correct. I just mentioned 808nm because its a common pump diode for green lasers. You wont see many cheap hand held lasers that are over 808nm. And without an IR filter (most cheap green lasers wont have one) you can still damage your eyes if your goggles are rated for green (532nm) only. Your goggles will need to include IR as one of the protection features.
Also very few lasers come with the correct reported power output. So you can have an over powered laser and not even know about.
Nice to meet another laser enthusiast.
Angus A Fitziron
« Reply #2679 on: March 20, 2010, 02:29:42 pm »
Cheers Laserpunk, I was lucky enough to be in the right place at the right time when fibre optics were introduced to telecoms! I was involved right from the early field trial days and didn't really move on until we had single mode 1300nm systems and just on the verge of WDM (wave division multiplex). Lucky man  Wink
Watts Industries
http://www.etsy.com/shop/WattsIndustries
WattsIndustries
« Reply #2680 on: March 21, 2010, 12:54:51 am »
Loving all the ray guns here! I'm new here and didnt realise there was such a vibrant community, it's really good to see everyone making ingenuous ways of zapping, disintegrating or however ray guns do there thing to each other Cheesy
heres my contribution.
pew pew zap zap
« Reply #2681 on: March 21, 2010, 01:57:50 am »
Thank you
good and cheap are often not synonymous, however as I see you are in the US I would suggest you use Sir Google to find a Tandy or Leather Factory near you: www.tandyleatherfactory.com
For holster, knife sheath,  and heavy pouch  (ie binoculars and instrument cases)  purposes I prefer 6 oz or so cowhide but not much heavier than 8 oz. You do not need high quality carving stock such as shoulders, but a good vegetable tan (as opposed to chrome tanned) belly, bends,  are both cheap and effective. Saddle Skirting is generally too stiff for our purposes and very clean shoulders and the like are reserved for fancy carving.
Avoid "other leathers" such as "splits",  pig, goat, deer, elk, etc as these are usually "soft tanned" for garment or upholstery use. You want stiff stuff, but you also want to avoid "rawhide" which is mainly used for drumheads, mocassin soles and Northern Plains Parfleche projects.
At the brick and mortar  stores you can find great deals in the "remnants bins" that you won't find in the catalog or online. You may also be able to get remnants of "latigo" which is both affordable and ideal for holsters as it is already died a deep burgundy-brown. It can easily be shaped to your sidearm or instrument by soaking the finished product in alcohol and jamming the implement into the holster, followed by forming with fingers, rounded sticks, etc.
more on these processes can be found here:
http://www.secretsquirrelleather.com/buildaholster.aspx
http://www.survivalistboards.com/showthread.php?t=84650
http://www.ar15adviser.com/forums/index.php?s=e5b9aa40295112fca87d95c602e45062&showtopic=15057
http://www.ggaub.com/ltag/mods/holster_leather_molded_drone.html
Alternatively, for lightweight replicas one can use Kydex, or its inexpensive thermoplastic counterpart found in  opaque Clorox Bottles, Kitty Litter Bottles, and small trash cans. One can google "making a kydex holster" for more on that.
prof marvel
« Last Edit: March 21, 2010, 06:15:03 am by Prof Marvel » Logged
Supplying useless advise for All Occasions
NevilleYardley
mhsmith22
« Reply #2682 on: March 21, 2010, 06:11:24 am »
pew pew zap zap
Wow! Thus could be witout a doubt my favorite ray gun thus far!
FANTASTIC JOB!
~N. Yardley
"I WANT TO LEARN WHAT MUST BE KNOWN!"
~Schwarzwald
Laserpunk
« Reply #2683 on: March 21, 2010, 07:56:45 am »
Yes you are. I'm just a hobbyist really. Pointers, laser shows, and such.
pew pew zap zap
Very nice!! Keep up the good work.
Watts Industries
WattsIndustries
« Reply #2684 on: March 21, 2010, 04:00:55 pm »
cheers Laserpunk and NevilleYardley Cheesy
thers some LEDs in it that flash and mix colours when you pull the trigger
Story
« Reply #2685 on: March 22, 2010, 03:38:06 am »
Seen today in Timonium, MD - a prop from the Will Smith movie WILD WILD WEST - seen in the opening credits and briefly, hanging on the wall of weapons in their Pullman Car.
It's a Belgian-made 'Montenegrin' design, originally in .44 Winchester. A bolt has been drilled through the bore, holding the scope (actually, a broken microscope) and the firing pin nipped off the hammer. Engraved brass plates appear to be epoxied to the cylinder & ventilated tubes added.
Price? $3200, with documentation.
Yeah, I have the guy's email if anyone's seriously interested....
        Drops to a ten-rupee jezail
« Reply #2686 on: March 22, 2010, 05:51:29 pm »
Would be way better without all the extra bits added..
Finnlock
« Reply #2687 on: March 22, 2010, 06:55:39 pm »
Not really steam punk at all, but I wanted to share.I finished these bolt pistols up the other day, a matched pair, left and right for my GF's sister of battle costume.
Finnlock
Capt_Zaphod
Chrono Corps Agent:42
Captain_Zaphod
« Reply #2688 on: March 23, 2010, 12:38:58 am »
My latest acquisition:
The Vaporizer Ray Gun, with stand.
« Last Edit: March 23, 2010, 12:41:36 am by Capt_Zaphod » Logged
Hallward
Le Renard
« Reply #2689 on: March 23, 2010, 02:41:24 am »
Finnlock those bolt pistols are fantastic.
MagnaRyu
« Reply #2690 on: March 23, 2010, 03:38:22 am »
Those Bolt Pistols are pretty sweet.
What was the process of making them?
Miss Romwell
An aspidistra.
Azura
« Reply #2691 on: March 23, 2010, 11:51:59 am »
Hello! Please forgive my noobishness!
I'm just about to start my first full outfit, and as a lady who doesn't do half measures, I want a nice weapon to go with it. ^_^
Because this is my first project, and I want the thing to function, I'm going to mod, rather than make from scratch. I know Nerf guns are popular, but I was wondering, has anyone modded a foam disc launcher before? I've looked around but can't find any examples.
Here's what I'm working with.
My intention is to turn it into 'The Ladies Compressed Air Throwing Star Gun, or Le Viper Japonisme Pneumatique Pour Madame'. XD Yeah, I know....
I've discovered that the mech will launch any flat shape, so I can mod the ammo, too. I'm going to add a belt mounted faux mini gas bottle and connect it with some steel hose, as well as attacking the whole thing with epoxy putty to smooth out the shape before I make additions like a pressure gauge ect. and give it a paint job. Can't decide on whether to paint the disc magazine or not, I quite like the transparent dayglo yellow cos it reminds me of uranium glass.
Any hints, tips suggestions? Has anyone modded one before? I'll be posting updates as and when. Smiley
« Reply #2692 on: March 23, 2010, 12:42:03 pm »
You seem to have the aesthetics well covered there, and if I have a dig around, I should be able to find a thread with painting tips:
http://brassgoggles.co.uk/forum/index.php/topic,21862.0.html
http://brassgoggles.co.uk/forum/index.php/topic,16668.0.html
Hope this is of use to you!
Oh, and welcome to the forum!
''I tolerate this century, but I don't enjoy it.'' Mark Gatiss
Miss Romwell
An aspidistra.
Azura
« Reply #2693 on: March 23, 2010, 01:07:17 pm »
Many thanks, Herr Doktor!
I just hope my modding skills match up to my lofty ambitions! Grin
The Kilted Yaksman
« Reply #2694 on: March 24, 2010, 03:25:11 am »
They've got the full line on Ebay.  I've been eyeing them...
"Those who can make you believe absurdities can make you commit atrocities."-Voltaire
Finnlock
« Reply #2695 on: March 24, 2010, 04:42:05 am »
It can be found here,
http://z6.invisionfree.com/Obscurus_Crusade/index.php?showtopic=74
 I have a lot of "How I did it" photos not pictured in the thread as well, maybe some day I'll make a page for it..
Finnlock
Major Twangy Rubber
« Reply #2696 on: March 24, 2010, 11:37:22 pm »
It's "show off the raw materials" time!
I picked this up over Christmas from someone who just didn't want it any more... I think it has potential!
« Last Edit: March 24, 2010, 11:40:24 pm by Major Twangy Rubber » Logged
Captain Billbill
« Reply #2697 on: March 25, 2010, 09:04:12 pm »
Well done all. Like the bolt pistols,and all the other ray guns... Im so glad I can come here for inspiration in my own humble quest to make more guns.
Khunag
Poland Poland
« Reply #2698 on: March 25, 2010, 09:17:39 pm »
This is what I just found:
Very cool shape and nice size, should make a great prop after only some minor modification and a paintjob Smiley
http://www.etsy.com/shop/khunag
http://myworld.ebay.com/epiminis
Always something for sale: steampunk, cyberpunk, industrial and wargaming related items.
« Reply #2699 on: March 25, 2010, 09:43:31 pm »
He He. That pistol caused a bit of a 'flap' on some of the prop making boards, as it's clearly based on the Bladerunner blaster!
Pages: 1 ... 101 102 103 104 105 106 107 [108] 109 110 111 112 113 114 115 ... 150   Go Up
Bad Behavior has blocked 1399 access attempts in the last 7 days.
Page created in 0.391 seconds with 20 queries.
