February 09, 2012, 11:41:39 pm *
Pages: 1 ... 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 ... 150   Go Down
Author Topic: A Collective Thread for All Them Guns  (Read 270357 times)
clockwork creation
Rapscallion Smile
« Reply #2400 on: January 03, 2010, 09:54:30 pm »
So I went up to mum and dads place today to help dad clean out his workshop as they are moving house.
Amongst the box of old tools I scored there was a saw handle that begged to become a gun handle.
An afternoon (well - evening too) session in my workshop and I have the first draft of 'Bianca' built.
Crappy camera phone picture - sorry.
Anyway, I plan to keep all the brass bits brass, but I want to paint the handle and the ceramic insulator to look like ivory.
I figure ivory would have been a good product to use for such parts 'way back when'.
Anyone have any tips on painting parts to look like ivory?
I look forward to seeing that finished
EliseVonTempest
You're a better man than I am, Gunga Din!
« Reply #2401 on: January 03, 2010, 10:53:58 pm »
Okay so I'm very new to steampunk and this is my first attempt at a gun alteration. It was a water gun I got for my birthday and while ago... I'm kind of ashamed to post, I feeling kind of like a small child on a tricycle trying to keep up with motorcyclists.
That's how it looked.
And this is how it looks now.
Any ideas to make it more steamy and interesting?
Much thanks,
Elise Von Tempest, Horticulturist.
I don't take coffee I take tea, my dear... And manner's maketh man as someone said... Takes more then combat gear to make a man, more then a liscense for a gun. Confront your enemies, avoid them when you can. A gentleman will walk but never run.
Titus Wells
« Reply #2402 on: January 03, 2010, 11:09:20 pm »
Don't be ashamed. Looks like a perfectly decent repaint to me. Many people have made a first attempt (or even secodn and third) with much worse results!
EliseVonTempest
« Reply #2403 on: January 03, 2010, 11:23:43 pm »
Thank you very much.
clockwork creation
Rapscallion Smile
« Reply #2404 on: January 03, 2010, 11:39:11 pm »
Seconded. Well done miss.
« Reply #2405 on: January 04, 2010, 12:52:12 am »
Thirdeded!
I wish I could repaint things that neatly and that smoothly - well done (and the perfect weapon for a horticulturalist)
'...Lockstock stonedead shock of a Dog Fenn frown'.
Iron Council - China Mieville
EliseVonTempest
« Reply #2406 on: January 04, 2010, 01:26:23 am »
Thirdeded!
Awww you are all too kind.
« Reply #2407 on: January 04, 2010, 11:23:08 am »
Thirdeded!
You are most welcome milady - as far as making your little stampunk squirter steamier, you could cut the heads of brass screws (or use brass dome nuts) and glue them over the moulded screws. This may give the gun a more 'built' look. A round item (watch gear wheel?) glued on the top of the round protusion to one side of the gun may act as a dial device for setting the guns impact. Some weathering of the item with paint effect (if you are into weathering items) may add to a more realistic look. Otherwise - consider it finished and move on to the next project I say!
Dusza Beben
« Reply #2408 on: January 05, 2010, 04:08:37 am »
I like the Ivory handle idea quite a bit! Though I would be inclined to leave the insulator, well, an insulator.
DB
jstorm
Intrepid Motorist
« Reply #2409 on: January 05, 2010, 05:37:08 am »
Picked this up at Big Lots (close out store here in the states) today while looking at toys with my oldest boy.  It had an interesting look so I had to have it.  IM gonna paint it and add some bits as well as a leather shoulder strap.  The only thing I dont like is the "barrel". Its clear plastic and has an orange corkscrew thing inside that spins and had LEDs on it that flash in  sequence.  Im thinking of just frosting the clear plastic and unhooking the speakers so you cant hear the lame sound effects.  Any suggestions would be appreciated, this will be my first mod for a weapon.
If you want to survive in this galaxy you have to know where your towel is.
Mr. Hatchett
Unnaturalist
« Reply #2410 on: January 05, 2010, 03:58:13 pm »
What kind of tools do you have to work with?  Would you be able to, say, get a pair of filigreed plates of relatively thin brass (like the decorative heating vent covers they sell at hardware stores,) cut and bend them to conform to the shape of the barrel and throw something translucent under it, like a sheet of colored acetate?  You'd have a vented brass barrel through which you could see the glow when you pull the trigger.  Maybe bracket it with some small diameter brass or copper pipe in the recesses between the main barrel and the two strips of clear plastic, and saw off the plastic handle on the top to enhance the key shape of the gun?
With the main mass of the weapon situated so low in relation to the grip, it looks like a prime candidate for conversion into a prosthetic cannon arm.  You could go crazy with it and take it all the way back to your elbow with some heavy PVC pipe, some creative sawing and a lot of paint or plating.  If you don't want any plastic showing, you can always bolt brass sheet down to the pipe.
I don't know what the plates are called, so I sketched it out.
« Last Edit: January 05, 2010, 04:29:35 pm by Mr. Hatchett » Logged
Utini420
« Reply #2411 on: January 05, 2010, 04:15:47 pm »
I like Mr. Hatchet's ideas, and yours of dropping the speaker.
If you don't have the tools to work in metal, you might try something else for a similar affect.  "Masking," might give a neat effect, if you try something like this:
1. Frost the plastic (disassemble it and frost the inside)
2. Put down little rows of round stickers.  Small ones, like 1/4 inch diameter, pick them up from a craft store.  Lay them on in rows like the venting on the barrel of a machine gun.
3. Spray with one of them textured, "Hammered Finish" metallic spray paints
4. When dry pick off the stickers.
Now you have a metallic barrel with venting that the glow will show through.
Mr. Hatchett
Unnaturalist
« Reply #2412 on: January 05, 2010, 04:30:56 pm »
That's a lot less metalwork and expense than my idea.  I like it!
Utini420
« Reply #2413 on: January 05, 2010, 04:44:18 pm »
Lolz.  All it would take is finding the right bit of brass at a thrift store, and I'd want to do it your way!  Grin
jstorm
Intrepid Motorist
« Reply #2414 on: January 05, 2010, 04:53:49 pm »
Ive got tools, I do auto restorations and used to work for a sheetmetal fab company. I like your idea,especially the prosthetic arm one.  Im going hunting today in search of more parts for it  and will let you knw what i find.
Khunag
Poland Poland
« Reply #2415 on: January 06, 2010, 03:01:01 pm »
Simple water gun conversion I did yesterday:
Reminds me of Protoss from Starcraft ^^
« Last Edit: January 06, 2010, 03:03:08 pm by Khunag » Logged
http://www.etsy.com/shop/khunag
http://myworld.ebay.com/epiminis
Always something for sale: steampunk, cyberpunk, industrial and wargaming related items.
SashaGears
Black Market Treasure Hunter
hexinfiniti
« Reply #2416 on: January 06, 2010, 06:54:31 pm »
uhhhm, that's pretty epic, looks alien.
"We're incredibly misunderstood, and so they label us witches...we're locked away in Containment zones, by those who would condemn us."-Noah, Arc of Gelen
Captain Billbill
« Reply #2417 on: January 06, 2010, 10:13:18 pm »
Another one of my favorite squirt guns to mod.  Nice Job.
SashaGears
hexinfiniti
« Reply #2418 on: January 07, 2010, 12:12:53 am »
some more pics of my bow, and some new pics of a small GASP toy gun mod I made, it's like..a revolver-flamethrower, called the Magnus, and the bow's name is the Sagitarius.
I uploaded them to tinypic because...well, the files are HUGE and I didn't want to stretch rape your pages.
Sagitarius{sloppy painting, and yeah, I know...a decorative gear, so scary...}
Magnus {The gears on the sides of them, on the knobs, are actually used as grips to turn the nobs, which makes an orange light(that isn't in yet) come out of the front to look like fire :3
cyberjacques
Inventor, Member of the Van Helsing Society
« Reply #2419 on: January 07, 2010, 05:06:14 am »
The grip on that pistol is really cool!  It looks kind of like tile or mosaic, but very aged.  I think that tiny Arabic style of inlaid mosaic would look nice on a weapon, and yours reminds me of that.
"To mewl and blabber about a treasure map, in front of this particular crew, demonstrates a level of ineptitude that borders on the imbecilic.  And I mean that in a very caring way."
                                                     ~Captain Amelia of the RLS Legacy, Treasure Planet
SashaGears
hexinfiniti
« Reply #2420 on: January 07, 2010, 05:42:36 am »
thanks, the grip was actually kind of hard to make, I had to cut into it with this wierd knife tool thing over and over but I think it turned out pretty snazzy :]
and it's supposed to resemble a black market weapon so arabic descent= goood :3 thanks
Captain Billbill
« Reply #2421 on: January 07, 2010, 04:40:01 pm »
Here is a quick mod I did to the Cyclone gun.
SashaGears
hexinfiniti
« Reply #2422 on: January 07, 2010, 07:38:49 pm »
Bill, not critizing it as that's a pretty good paint job, but I'm wondering if perhaps it looks a little too painted? like...plasticy painted?
are you planning on doing any sort of metallic texture or adding weathering? if so i HIGHLY recomend hammered spray paint and antique gold or goldleaf rub n buff, it gives an amazingly realistic effect when combined.
but that still looks decent.
mercenaryluther
« Reply #2423 on: January 07, 2010, 11:21:53 pm »
These are my first steampunk projects. I'm not done with them but i was hoping to get other peoples thoughts on this.
mercenary  bounty hunter  trasure hunter  body guard  solder.  I might have a small voice but a carry a big stick.
SashaGears
hexinfiniti
« Reply #2424 on: January 07, 2010, 11:46:27 pm »
nice luther, you don't see like grating or whatever those little ornate sheet things are on a maverick mod usually.
I like them
Pages: 1 ... 90 91 92 93 94 95 96 [97] 98 99 100 101 102 103 104 ... 150   Go Up
Bad Behavior has blocked 1398 access attempts in the last 7 days.
Page created in 0.423 seconds with 19 queries.
