CptCombustable
 United Kingdom
Oh, there's light alright...but no tunnel
« Reply #100 on: April 13, 2009, 08:01:04 pm » |
VERY nice
WoahWomanLillyWahWahBeepBeepBoppaLulaWoahYeah
 United Kingdom
« Reply #101 on: April 13, 2009, 08:13:00 pm » |
So, when I purchase one of these, does it come with a little tube of glue or do I have to buy that saparately?
In fact, Can I have about twenty of them, ready for my Pirates show in spring next year.
Dr. Q.
darkshines
 Wales
Miss Katonic 1898 + Cowperthwaite's other half
« Reply #102 on: April 13, 2009, 08:14:24 pm » |
That gun is making me think very unladylike thoughts!
Rowan of Rin
 Australia
~The Black Blood Alchemist~
« Reply #103 on: April 14, 2009, 02:24:16 am » |
Oh my..
I'll be in my bunk.
Milo Addle
« Reply #104 on: April 14, 2009, 02:39:15 am » |
The gray makes it look a little unfinished
« Reply #105 on: April 14, 2009, 03:12:10 am » |
The craftsdwarfship is of the highest quality. Excellent as usual, Sir.
« Reply #106 on: April 14, 2009, 03:15:50 am » |
Just lovely.
I think your final colour choice will make or break this one, any ideas yet on final finish?
How about a deep shiny metallic blue/green to contrast with the brass trim - do they do that in Rub 'n Buff?
And I too am experiancing some ungentlemanly thoughts when I imagine wielding this wicked weapon (or any other weapon for that matter).
'...Lockstock stonedead shock of a Dog Fenn frown'. Iron Council - China Mieville
 United Kingdom
« Reply #107 on: April 14, 2009, 07:47:49 pm » |
Why, thank you! And I think I've found a finish- I read, somewhere, that Halfords zinc primer can be wire-wooled and polished to a pewter like sheen, so I've tried it on a swatch: primed, then the zinc primer, left to cure, scotchbrite to break the surface, Autosol to get the shine, then grate-black polish to finish:  Excuse the slight lack of focus, and the scratches- both are down to my impatience! The shine is very deep, if you put your finger against it, you get a good reflection, so this is how I'm going to procede!
« Reply #108 on: April 14, 2009, 11:29:13 pm » |
Looks like a good technique there - be sure to photograph the stages of the paint and finish application for us to all go 'ooooooh' and aaaaah' (and 'uh oh') over.
 United Kingdom
« Reply #109 on: April 15, 2009, 12:06:41 am » |
I've pretty much used up a 300ml rattlecan of the zinc primer, giving three good coats to all the parts, just got to leave it overnight to harden, then I'll start the polishing- I'll take a 'before' picture, it looks like dark grey primer till you knock the surface back, so the difference is quite noticeable...
Alexander Edmund Clough
« Reply #110 on: April 15, 2009, 12:48:53 am » |
Bravo Dok, Bravo.
Another masterpiece!
So God Save the Queen, 'Cause anything is possible for a man in a top hat with a monkey with a monocle!
 United Kingdom
« Reply #111 on: April 15, 2009, 01:07:49 am » |
That sounds like a most interesting prospect. Always good to know these little tricks of the trade.
I assume that all the twiddly bits will be detailed with your usual aplomb, panache, je ne sais quoi and stuff.
Dr. Q.
Prof. Albrecht Von Taggërt
« Reply #112 on: April 15, 2009, 02:55:42 am » |
Excellent choice in color as per usual Dok!!
Please don;t keep us in suspense to long!! (BTB be on the look out for something from me soon =) )
Mr. Hatchett
« Reply #113 on: April 15, 2009, 03:32:30 am » |
I'm really looking forward to the next set of shots!
 United Kingdom
« Reply #114 on: April 15, 2009, 11:46:38 pm » |
Right, been in the workshop since half past six up to eleven, with only a half hour break for supper; so, here's what I've been up to: this is what the zinc primer looks like when first applied:  And after a darn good polishing with silver polish:  I came to the conclusion that silver polish was best after trying brass and copper polish, T-cut and Brasso- the silver polish was the last that I tried, and it worked the best! And now, with the final polish done with grate black, and assembled:  It's not very easy to photograph, ie to pick up how good the metallic sheen is, but this is the best I can manage, I think it would be better under daylight. I still need to do some of the details; the two spigots for the H20 and H2SO4 need to be painted, I was thinking red for the sulphuric acid and blue for the water, and I want to polish up the brass tubes, then of course there's the decals for the water and acid tanks, and the labels for the projectile selector, and I still need to finish the pressure gauge... The mags aren't attached as I'm waiting for the various layers of paint and polish to fully cure before I snap them in!
« Last Edit: April 16, 2009, 05:25:52 pm by Herr Döktor »
« Reply #115 on: April 16, 2009, 12:39:34 am » |
Magnificant!
That primer paint and polish look certainly worked.
Please remind me what 'grate black' is so I can source some, I like the way it gets in the cracks and around the studs.
A fitting companion to wall mount with your blunderbuss.
Now what are you going to do next???
 United Kingdom
« Reply #116 on: April 16, 2009, 12:53:01 am » |
Black grate polish- the old fasioned stuff that grand mama used to make the fire basket look nice and shiny! You need to find the spirit based stuff, as recently the classic polish by Zebo has been replaced with a water based version, no where near as good! I'm really pleased at the polished zinc effect, I expect everything I make will have this finish for a while! As for what's next: hmm... I've still got to find a use for that horn gramophone...
Ancient Tinkerer
« Reply #117 on: April 16, 2009, 01:55:26 am » |
Just stunning. Now that you have figured out how, you must make another and case them as dueling raypistols. 10 paces and turn.
Marvelous work.
john
silastic armor fiend
« Reply #118 on: April 16, 2009, 02:24:50 am » |
Just stunning. Now that you have figured out how, you must make another and case them as dueling raypistols steam pistols. 10 paces and turn.
Marvelous work.
john
fixed. absolutely fantastic work, herr doktor! may you inspire us all to rise to new levels of awesome.
in this town of sleepy hollow, smiling like you do in this town of sleepy hollow, could be me and you
darkshines
 Wales
« Reply #119 on: April 16, 2009, 09:40:25 am » |
Oh. My. COG.
Can I commision you to make me a fire arm? I was going to try, but anything I attempt will pale in comparison to this beauty!
« Reply #120 on: April 16, 2009, 10:34:26 am » |
Oh. My. COG.
Please have a go at making your own weapon that captures your ideas and your aesthetic. I too am in awe of many of the good doctors technical skills, but at the same time I use that awe as inspiration to try my hand at something, rather than as a yardstick I cannot measure up to. But I cannot speak for HD who may welcome the work of course - particularly if asked sweetly by a fine young lady. Nevertheless - I would encourage you to use this forum to discuss your weapon design ideas, post pictures of parts, seek advice on assembly and finish and ultimately wield your own weapon with pride (and a gleeful green eyed glint).
darkshines
 Wales
« Reply #121 on: April 16, 2009, 10:56:58 am » |
*giggles* I must confess, every time I use my hair dryer, I pose with it link a gun, its the perfect shape. I have never made a fictional fire arm before though, they have always been based on a historical blueprint. And have just been stage weapons, the rule of thumb being "if the front row can't tell its a hair dryer, you're ok".....
David Godfrey Esq.
« Reply #122 on: April 16, 2009, 12:52:11 pm » |
Rule two being "Don't give it to the actors yet they'll break it!"
Reunite Gondwanaland!
David Godfrey Esq.
« Reply #123 on: April 16, 2009, 12:57:49 pm » |
Herr Döktor, amazing as always. Again you set the standard to aspire to. Yet again my hat's off to you sir.
 United Kingdom
« Reply #124 on: April 16, 2009, 02:43:34 pm » |
That is a sharp looking piece of work, doc.
So, it's a trip to Halfords then.
Also, Water based Zebo!!!??? What is the world coming to?
Dr. Q.
