July 20, 2018, 12:52:52 am *
Author Topic: need advice connecting crank to generator  (Read 650 times)
Hmbab2000
« on: April 25, 2017, 04:09:49 pm »
I'm trying to connect a few pieces but am having a hard time.
I need to connect the crank from this pepper mill to the generator shaft.  The pepper crank is threaded but is over sized for the generator shaft.  The shaft is round with a center that is threaded. Any thoughts?
« Reply #1 on: April 25, 2017, 06:06:54 pm »
How about a tube that fits nicely over the shaft, sized to let the shaft sit flush with the other side of the hole, and a screw and washer that goes into the hole in the shaft to keep it all in place. If a bit loose, some loktite or epoxy will keep it all together.
Thus:-
Where |---   is the shaft with cog
          ===  is the tube
           --+   is the screw
         |        is the crank wheel
Hope this makes sense?
(egad! Ascii art! I apologise... Embarrassed
Hmbab2000
« Reply #2 on: April 25, 2017, 06:38:42 pm »
That's a certain possibility.  I'd really love to utilize the existing thread of the crank and not see an exposed screw.  But perhaps a nice brass flathead...
So i understand.  Your proposing a sleeve over the existing shaft to fill the crank hole.  Then find a screw that fits the threading of the shaft, drill through the crank arm, and secure?
« Reply #3 on: April 25, 2017, 06:44:36 pm »
Another option would be to sleeve the shaft as above, but thread the outside of the sleeve to match the thread in the crank. I don't know if you're set up for that sort of thing, though.
Hmbab2000
« Reply #4 on: April 25, 2017, 08:36:12 pm »
You pulled the thought from my brain. The sizing is so slight though. Still need to attach the crank shaft. ..
Or perhaps a steel sleeve tube over the generator shaft,  a pin through the existing shaft hole (see pictures above), then thread the sleeve.  I'm only stopped by finding the sleeve, or if I can find it. I may have to enlarge the current threaded hole based on sleeve thickness. Is cast iron hard to drill and tap?
« Reply #5 on: April 25, 2017, 11:16:54 pm »
Not quite; the shaft seems to be a fit in the hole- assumed from the 2nd photo- so the sleeve on the shaft would be shorter than the shaft but wide enough for the crank wheel to sit on it when on the shaft. The screw than holds the crank against the sleeve, screwing into the threaded? hole in the shaft, so no drilling required.
As the honourable von Corax mentioned, threading the sleeve would be good too  Smiley
Hmbab2000
« Reply #6 on: April 26, 2017, 12:56:08 am »
Problem solved...
A small brass plumbing fitting from hardware store, some drilling and filing, waa laa..
« Reply #7 on: April 26, 2017, 06:25:48 am »
Yes, when you have problems like that, look for an adapter. Try to get one that at least fits the hole, and, worst case, has a hole in it too small for the shaft. Holes can easily be drilled larger, and tapped with threads if necessary.
« Reply #8 on: April 26, 2017, 06:53:49 pm »
Aha! Nicely done. Smiley
And a spring clip to boot, making for easy removal!
Hmbab2000
« Reply #9 on: April 27, 2017, 01:14:09 am »
Now that it's a working unit, it's being refined. A little heavier since the crank action isn't "easy" and the brass is so soft, i dont want it to tear.
Thank you for the inspiration...
I'm making a slide viewer with hand generated power to energize a 12v light. I harvested several pieces and parts to make a unique piece.  Here's a progress picture...
Page created in 0.235 seconds with 16 queries.
