March 24, 2018, 12:02:12 am *
Author Topic: Odd Connector Wanted  (Read 483 times)
Lord Pentecost
« on: April 11, 2017, 07:30:01 pm »
Does anyone on here know if it is possible to get some sort of connector (or a combination of fittings) to connect a standard photographic tripod tread to an M10 (10mm) thread. I am looking add a light fixture to an old brass tripod I recently acquired.
« Reply #1 on: April 11, 2017, 07:44:29 pm »
I'm assuming that the tripod is the male thread- so you need a 1/4" 20tpi female thread to a 10mm male?
I would try pneumatic adapters for compressed air - there are many suppliers in the UK, they should have something suitable, but I'm not sure what they would call them...
« Reply #2 on: April 12, 2017, 07:36:41 pm »
Not sure if this could help in any way. If the Tripod is brass, this could be sleeved/ drilled and soldered as required if no alternative can easily be found.
I use these alot in builds of every kind.
munsen ring extension M10 thread m+F.........
Or Female base ?
« Last Edit: April 12, 2017, 08:08:57 pm by SeVeNeVeS » Logged
Page created in 0.022 seconds with 16 queries.
