June 20, 2018, 03:08:09 am *
Author Topic: Best way to make flip down lenses for goggles?  (Read 717 times)
Okapis Rule
« on: June 29, 2016, 01:11:42 pm »
So I have plans to make some more goggles, and I would like to add those flip down lenses on a rod that I see on a lot of other goggles.  However, I have no idea how to start.  What sort of rod do I use so that they have the right amount of friction, and where do I find/how do I make the lenses themselves?
If anyone is unsure what kind I'm talking about, it's the ones that look like this:
Thanks!
Aren't we trying to re-create the historical time when a man would wake up, don his goggles and fly his airship off to fight Martian invaders with a ray gun?
-Dr. Fidelius
Kensington Locke
« Reply #1 on: June 29, 2016, 03:50:30 pm »
I just bought a clip on set of those lense thingies at a convention.
I don't think I can post a picture directly, so let me describe it to you.
each lense is on a long arm (the arms on mine are hexagonal).
the arm enters a small clamping block with screw, so you can adjust the lense distance from the block
the block has a second hole that a long screw is slid into.
I have 3 lenses on mine, so that's 3 block/arms stacked onto this screw
after the 3 blocks, is a spring, supplying tension to the blocks (so they don't flail about)
then the squeezy clip (for clipping to glasses frame on the side)
then the nut for capping this all off.
So in bad ASCII art, here it is:
T
B--------L
B--------L
B--------L
S
S
S
C
N
I'll see if I can snap a pic, put it on a photo hosting site and link it proper.  It's a simple device really.
Kensington Locke
« Reply #2 on: June 29, 2016, 03:58:45 pm »
A picture's worth a thousand words and a bit of googlefu revealed it.
Apologies for posting to a vendor, but it's the first hit I got and I don't think I should nab the image from their site.
https://www.amazon.com/Hawk-MG922D-Clip-Double-Loupe/dp/B000YMZJX2
This is basically just like what I bought, same knurling on the ends of the screw pole.
then end where the clip is is the threaded part, so you could unscrew it, swap out the clip for something that connects to your goggles and put the end nut back on.
That was my basic plan to mount them to my goggles.  I felt the closest lense was scratchingly close to my actual glasses lense when I tried clipping them on.  Might need a longer screw pole.
Lord Pentecost
« Reply #3 on: June 29, 2016, 07:15:40 pm »
Search ebay for "clip on jewellers loupe" if you want coloured ones I would suggest a second search for "glass paint"
« Last Edit: June 29, 2016, 07:17:18 pm by Lord Pentecost » Logged
Okapis Rule
« Reply #4 on: June 29, 2016, 07:48:43 pm »
Alright, thanks!  I'll probably just end up buying one then; they seem reasonably priced.
« Reply #5 on: June 29, 2016, 08:39:17 pm »
I had been picturing the Dwayne Wayne flip-up lenses.
Serrac
« Reply #6 on: June 30, 2016, 12:14:58 am »
Alternatively, have a look at camera lens filters - These come in quite a wide range of sizes and colours, but the glass ones can be quite thick (typically, 2-3mm). If you want thin, then I'd suggest some lighting gels which are around 0.25mm thick.
See if you can blag a swatch book from a Lee Filters supplier (or have a look at http://www.leefilters.com/lighting/lighting-resources.html )
If I leave my grin behind, remind me that we are all mad here. (SJ Tucker: Cheshire kitten)
« Reply #7 on: June 30, 2016, 01:00:45 am »
Harbor freight use to carry them.
Page created in 0.077 seconds with 16 queries.
