September 23, 2018, 12:09:14 am *
Author Topic: Lightbulb Shining Since 1901  (Read 697 times)
chicar
Chicar556
« on: June 08, 2016, 05:08:12 pm »
A Egnigma Whose Answer Could Be Quite Pratical:
http://www.centennialbulb.org
Server Monk
« Reply #1 on: June 08, 2016, 11:11:56 pm »
Nothing really special about it - it's simply a circa 40W incandescent lamp that is running at around 4 - 6 watts. Basically it is a higher voltage bulb, say 220V, that is running on 110V, with the result that it runs lower wattage and thus the filament is at a much lower temperature. At reduced power levels you can vastly increase the expected life of any incandescent lamp.
It also helps that the lamp has rarely lost power, so has not been exposed to the repeated strain associated with the usual heating / cooling cycles that affect the life of other lamps. This is why incandescent lamps tend to 'blow' when they are switched on, rather than during use.
[Server Prayer]
steiconi
« Reply #2 on: June 15, 2016, 01:34:34 am »
Thanks for posting that.  I used to live not too far from Livermore and heard about the long-burning bulb every now and then.  Just the other day, I wondered if it was still burning.  You go, bulb!
« Reply #3 on: June 15, 2016, 06:20:09 pm »
Can we rule out that this isn't some kind of elemental spirit imprisoned by a magician?
Page created in 0.025 seconds with 16 queries.
