April 25, 2018, 09:49:06 pm *
Pages: 1 2 [3] 4 5   Go Down
Author Topic: #467  (Read 5633 times)
« Reply #50 on: August 13, 2015, 08:13:01 pm »
« Reply #51 on: August 14, 2015, 04:00:33 am »
Can't you work faster than that?!?!
 Cheesy
See, still watching. Wink
« Reply #52 on: August 14, 2015, 09:58:59 am »
Still leading us on, selected! Grin
« Reply #53 on: August 14, 2015, 09:14:56 pm »
Slowly coming to a end
 Cheesy
3 hours to file out those cuttings.
Far too long.  Grin
« Reply #54 on: August 14, 2015, 09:33:51 pm »
 Huh
« Last Edit: August 16, 2015, 05:50:16 am by selectedgrub » Logged
« Reply #55 on: August 14, 2015, 10:21:00 pm »
So it's a speaker cabinet?
Looking good.
« Reply #56 on: August 15, 2015, 01:40:10 am »
 Cheesy Thanks man.
Opens like book.
« Reply #57 on: August 15, 2015, 11:44:41 pm »
 Huh
« Last Edit: August 21, 2015, 08:53:44 pm by selectedgrub » Logged
« Reply #58 on: August 16, 2015, 04:07:01 am »
Ok, technical here: what make of driver and what will power it?
« Reply #59 on: August 16, 2015, 05:11:47 pm »
Looks like a guitar amp or maybe a subwoofer to me.
Darn fine work Mr Grub (was tempted on the heavy metal music comment, but resisted  Tongue)
Is this going to be portable? the original part looks very much like a handle.
« Reply #60 on: August 16, 2015, 07:44:04 pm »
Yes, looks like to me as well. Smiley
And you are right it is quite heavy.
My Stereo, after the membrane split on Wharfedale speaker I needed another.
I don't know much about audio.
It is a Digital design speaker.
http://www.ddaudio.com/products/mobile-audio/mids-highs/coax-and-components-hybrids/cxs-65
As it's only mid I think I might make box underneath for subwoofer
« Reply #61 on: August 16, 2015, 07:54:51 pm »
I'm gunna try wider mesh but it looks good without when you can see the speaker.
« Reply #62 on: August 16, 2015, 10:53:42 pm »
Ah, DigitalDesigns, good stuff. Used a pair or 2 in my car audio days. Just remember they are 4ohm and not 6 or 8 as typical home audio speakers.  Wink
Repair kits are available for typical issues, but those take time and more techniques.
.....hmmmm, so you're making 2 of these....
SVNVS, Definitely NOT a sub = 2 drivers (a coax). Just saying....
« Reply #63 on: August 17, 2015, 02:28:45 am »
Looks like a gas jet!
« Reply #64 on: August 18, 2015, 07:05:07 am »
 Grin. True.
Drew do you think being 4Ω they will fry my deck?
There is controversy on this seems
« Reply #65 on: August 18, 2015, 02:02:15 pm »
If you listen at moderate to lower volumes= no, all should be fine. Although, continuous use will lead to a faster death.
So if you listen for a couple of hours at a time (say 4+) or at higher volumes= yes.
The amps will run hotter faster and, of course, that heat will cause components to wear quicker. Now, if you attach a small computer fan or 2 (1 to push, 1 to pull- 1 on top, 1 on the bottom or front to back, side to side) these could negate those effects depending on your use and how well the fans work.
So for 'background' listening it should be ok.
As an addition: some home audio amps are well suited for 6ohm loads and a occasional few can do 4ohm if split between 'A' & 'B'(if those units have A/B).
In short for practicle thought, halfing the ohmage doubles the power out from the amp, double power=double strain on items not meant to do that.
Obviously, your old Wharfedales (which are great!) were made for home use.
I have a pair of mid-line DALI and they are 6ohm and my crappy Yamaha receiver does just fine.
« Reply #66 on: August 18, 2015, 07:58:08 pm »
Thanks for the info.
I have doubts now may look for a more suitable speaker.
« Reply #67 on: August 20, 2015, 07:05:39 am »
Frame sandwiched, buried threaded post so can't see from front.
Fits in there.
Screwed from back.
« Reply #68 on: August 20, 2015, 01:04:49 pm »
Gotta love the detail.
« Reply #69 on: August 20, 2015, 07:56:06 pm »
Detail?
I haven't started that yet.  Grin
My inspiration was Industrial, Hans Giger stuff.
« Reply #70 on: August 21, 2015, 09:17:21 pm »
Couple of random pics
« Reply #71 on: August 21, 2015, 10:05:29 pm »
Now it comes together! It's interesting to find out just how big, or small a part actually is, compared to what it seems to be in it's own photo.
That should make a great sound with all that solid work.
Thanks and carry on!
« Reply #72 on: August 22, 2015, 03:49:48 am »
Will do, thanks.
I will fill inner with that carpety stuff to muffle just to be sure.
My main concern is nothing rattles.
« Reply #73 on: August 22, 2015, 11:06:45 pm »
Stemco hub cap hacked down.
Then notched to fit.
Prof. Convict Archfiend
« Reply #74 on: August 24, 2015, 02:37:24 am »
Really do wish there was a like button!!
Really starting to come together dude.
Mad skillz, mad! love it
Just call me "Greenie"....
(much quicker to type)
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.063 seconds with 16 queries.
