February 20, 2018, 12:36:07 pm *
Author Topic: Optical Gadgets For Beginners  (Read 1363 times)
Fracture
« on: December 07, 2013, 06:48:51 pm »
Hi,
I'm thinking of getting into steampunk and the first thing I want to make for myself is a set of goggles with different levels of magnification and color filters. I am getting a 3D printer soon so I should be able to make most of the mechanical parts but I'm not sure where to get the lenses.
Do any of you have experience making optical gadgets? Knowing cheap places to get lenses would be helpful but I could really use any advice you have.
Thanks,
-Fracture
« Reply #1 on: December 08, 2013, 01:39:28 am »
Gels from the theater lighting offer a lot of decorative options. The gels are a bit easy to tear.
Many of us started by modding welding googles, the lenses are about the same size in military flashlights.
An other option is the cling films used to "tint" automotive glass.
« Reply #2 on: December 08, 2013, 03:48:54 am »
If you have trouble finding them elsewhere, I made a set of red lenses for my goggles using clear plastic disposable picnic plates I found at the grocery (about $3). I traced out the size of circle I needed, then used a Dremel cutting wheel to cut it out, then lightly sanded down the rough edges. I'm sure they come in blue and yellow as well.
« Last Edit: January 23, 2014, 06:30:12 am by Herbert West » Logged
Keith_Beef
France France
« Reply #3 on: January 16, 2014, 11:47:55 am »
When I was looking at welding and brazing goggles, I found that there are different tints available, and I would expect that replacement lenses would be available, too. Try your local plumbing and welding supply shops.
Keith
Kevin C Cooper Esq
« Reply #4 on: January 16, 2014, 08:11:18 pm »
Thrift shops, anything cheap with a lens in to be cannibalised.
Page created in 0.038 seconds with 18 queries.
