July 19, 2018, 06:49:13 pm *
Pages: 1 2 3 [4]   Go Down
Author Topic: [Minecraft 1.7.X] Steamcraft2 Minecraft Mod [Beta 4.5] [Forge]  (Read 12305 times)
« Reply #75 on: December 18, 2013, 03:13:08 pm »
The ringed planet is Saturn. Also, look into Galacticraft and its handling of other planets.
violaambroseflux
« Reply #76 on: December 18, 2013, 03:34:41 pm »
I just put the idea out there, as for the the hostile to the players, bragging rights apart,
each world could contain a greater abundance of certain materials, like the end contains enderstone,
Saturn's rings could be multicolored cobble (mostly),
Pluto un-melting ice, etc.
as for Uranus and Neptune i agree the are similar but my suggestions are based on what i know or have read,
(mars is Barsoom, but Venus in Burroughs novels is a water world, but i went with jungle).
extra thought if Neptune is left as a frozen see, could Uranus be a frozen Nether
what about new plants, materials, if we have the morph ability then new mobs become trophies of a sort
as for the mountains of madness, Rylh etc they are ideas, maybe the only way to get elder stone( a geen grey stone) to make elder symbols and artifacts.
. Forgot to say rylh should be completely water filled dimension lol
any one who wants to add to my ideas, i welcome it, as for the nausea, there should be some way to bypass it i agree, but apart from a potion that requires mythos mobs i have no idea.
additional idea
the ability to move between world could also be achieved with space mead (potion)
and the morph ability could used to survive in the more hazards areas ( and bypass nausea), a deep one in rylh etc
any portal that has access to a dimension should also have a chance to spawn the dimensions critters like the nether portal and pigmen
who wants to do a mod based on mythos magik lol, that could be scary,
ps elShoggotho looking to you for shoggoth ideas :-)
I did give Saturn rings
Saturn: floating islands ( ground level), flying mobs, the lower you get the faster you drown, as the air turns liquid, rocky field high in the air ( above 128) from west to east each field is 20-100 blocks wide ( north to south), the higher in the ring the  different colored rock , possibly the floating spheres mod ( no idea what its actual names is ) as  moons
and Jupiter storms
« Last Edit: December 18, 2013, 03:38:19 pm by violaambroseflux » Logged
Major Vincent Smith
Eccentric Gentleman
Vampyre Lord of the Twilight Overlord of Hellfire
jacknife98
« Reply #77 on: December 18, 2013, 08:08:13 pm »
I will do my level best to make the dimensions less 'samey' with different mobs, structures, skyboxes and other stuff.  Wink I like these ideas guys - keep them coming!
« Last Edit: December 18, 2013, 08:10:09 pm by Major Vincent Smith » Logged
Spammers Flattened: 52
"Not on my watch!"
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #78 on: December 19, 2013, 05:55:19 pm »
In regards to dinosaurs - there is a guy offering these models that he has made which I can use in the mod if I get permission - what do you guys think:
http://www.minecraftforum.net/topic/1958671-raptorfarians-model-collaboration/
Augustus Longeye
Daedric Prince of Biscuits
« Reply #79 on: December 19, 2013, 06:13:49 pm »
VERY fancy models! That guy has some skills Smiley
~Longeye~
Quote from: Sir Nikolas
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #80 on: December 19, 2013, 06:14:32 pm »
Well, I guess I will go after them then xD Gonna send him a PM now!
EDIT: Wow! He was fast!  Shocked Guess I better get working on implementing them!
« Last Edit: December 19, 2013, 06:24:31 pm by Major Vincent Smith » Logged
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #81 on: December 20, 2013, 01:38:46 pm »
Considering the point of releasing these alphas is really just to show you what I am working on - Alpha v4 is now released. Check the main post for a link and rough changelog.
Since I am such a buggy coder - here is my brand new bug tracker - if you find a bug feel free to report it to me here: http://warlordjones.lighthouseapp.com/projects/115910-steampunkery/ Probably will be of more help when I have actual releases rather than alpha.
EDIT: just a quick note - I won't be updating to 1.7 any time soon. Forge has switched to Gradle which is a whole lot more work for less benefit and we don't even get to see the minecraft/forge source - learning by example is the only way I can code.
« Last Edit: December 30, 2013, 07:07:08 pm by Major Vincent Smith » Logged
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #82 on: January 19, 2014, 10:20:53 am »
Right, I now have a github repo setup for my code, so you can keep an eye on my progress Wink
https://github.com/BrassGoggledCoders/Steampunkery
Augustus Longeye
« Reply #83 on: January 19, 2014, 02:37:11 pm »
Github good (ish) Wink
Although what's this about 1.7 being gradle?
~Longeye~
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #84 on: January 19, 2014, 03:03:00 pm »
Forge have switched to a Gradle build system, not sure what that means other than apparently more complex setup, haven't experimented in 1.7 yet
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #85 on: February 15, 2014, 09:49:36 am »
Hmm. I have been invited to merge with this mod: http://www.planetminecraft.com/mod/164forge-steamcraft-2---the-rebirth-in-progress-night-vision-googles-guns-drills-steam/ He appears to be implementing some of the same things as I was planning, and appears to be a better coder than me - however I would lose some control over the mod. What do you guys think?
EDIT: I think I'm gonna go for it!
EDIT: On second thoughts - our coding styles are COMPLETELY different, it would a be a stupid amount of work to integrate the mod. So, looks like I am back to being on my own...
« Last Edit: February 15, 2014, 12:07:49 pm by Major Vincent Smith » Logged
Augustus Longeye
« Reply #86 on: February 15, 2014, 03:02:54 pm »
Yeah I'm not a huge fan of integrating with other programs.... starting out together is great if you come up with a spec list to start with, but merging halfway through is a huge task.
Personally I think you've made a good choice Wink
~Longeye~
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #87 on: February 15, 2014, 05:43:48 pm »
Oh, I really don't know now - his raygun is epic!
EDIT: Gah, right, decision made - stay seperate... merge. Had a skype talk with the guy, and he has convinced me - I needed to cleanup mu code anyway Wink
« Last Edit: February 15, 2014, 09:53:14 pm by Major Vincent Smith » Logged
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #88 on: March 04, 2014, 08:24:30 am »
Ok, so I have just about finished the merge (decided to go for it!) and am now contributing to www.github.com/BrassGoggledCoders/SteamCraft2 I will update this thread when we are ready for first release.
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #89 on: September 03, 2015, 11:55:19 am »
Phew, that took a while to blow the dust off this!
The mod has not been neglected, unlike this thread, but I thought I should post it over here as well as in MCF. The OP is now updated, with a few little oddities caused by me copying in directly from another forum.
Feel free to post any suggestion/comments you have for the mod here Smiley
Pages: 1 2 3 [4]   Go Up
Page created in 0.383 seconds with 16 queries.
