February 24, 2018, 06:55:57 am *
Pages: 1 [2] 3 4 5 6 7 8 9 ... 99   Go Down
Author Topic: Brass Blocks! The Unofficial BG Minecraft Server RETURNS!!  (Read 82847 times)
Augustus Longeye
Daedric Prince of Biscuits
« Reply #25 on: June 25, 2013, 09:37:54 pm »
Well arse of all arses. If you go "options" and "force update" it'll revert. However to correct it I may need to sacrifice a goat or something. I'll let you know....
~Longeye~
Quote from: Sir Nikolas
Augustus Longeye
« Reply #26 on: June 29, 2013, 11:59:41 am »
Okay, so the server has settled in (mostly), and I think it's time to look at starting up a communal build! What say you all?
My ideas for a good place to start would be "something that benefits everyone", like a communal power station everyone can tap into, an infinite supply of basic materials (cobble, oak, smooth stone?) or perhaps something completely different! Suggestions? Smiley
~Longeye~
Screaming Lord Pea Green
Where the only wrong thought...is the right one.
« Reply #27 on: June 29, 2013, 12:42:47 pm »
Well, we've had Warehouse 13 in THE PAST, so i'd like to put my vote down for a power station.
(plus, it'd help me understand how to build one Tongue)
...However, might I suggest we steam/dieselpunk it up somehow? With airships, or clockworkery perhaps.
The Moral High Gound - A great place to position Artillery.
Dr. makebot
« Reply #28 on: June 29, 2013, 01:10:43 pm »
I would put my vote down for power station as well.
yes I am a mad scientist, now live with it.
Ainuryn
« Reply #29 on: June 29, 2013, 02:10:00 pm »
I would vote power station as well.
"It could've been very different ...... alot less witches ..... alot more caffeine"
Dr Ephraimus Ironhatch
Augustus Longeye
« Reply #30 on: June 29, 2013, 03:49:40 pm »
Powerplant seems to be popular, but I certainly agree with Pea. Either have it IN an airship maybe? Or at least have steampunkery going on. We can also use things like turbines and frames to add moving elements to make it look cool.
~Longeye~
Major Vincent Smith
Eccentric Gentleman
Vampyre Lord of the Twilight Overlord of Hellfire
jacknife98
« Reply #31 on: June 29, 2013, 03:57:49 pm »
I vote power station also, but I cant connect to the server, as it is saying the error mentioned above about advanced solar helmets. Could you tell me the ids for the three items show above, so I can manually edit my config?
Spammers Flattened: 52
"Not on my watch!"
« Reply #32 on: June 29, 2013, 04:15:08 pm »
You can revert to standard config until it's fixed.
I have no opinion. I shall build my world piercing tower, one story at a time. From bedrock to the sky. Then I'll add portals to all the standard worlds.
« Reply #33 on: June 29, 2013, 04:52:26 pm »
~Longeye~
*steeples fingers*
EX-CELLENT!
Dr. makebot
« Reply #34 on: June 29, 2013, 06:55:48 pm »
I have marked out a possible construction site, you can get there via one of the spawn portals.
« Reply #35 on: June 29, 2013, 08:01:40 pm »
Personally, I despise giant scars on the landscape to "mark out" projects, i'll build elsewhere...
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #36 on: June 30, 2013, 09:34:49 am »
None can help with the error?  Cry
« Reply #37 on: June 30, 2013, 03:49:31 pm »
As I said before: REVERT TO THE STANDARD CONFIG FILE. Force update FTB Ultimate, that should do it.
Augustus Longeye
Re:
« Reply #38 on: June 30, 2013, 04:15:16 pm »
If, in the ftb console, you select "options" and then "force update" that'll do it for now. Do we have any thoughts on a style then? Maybe certain types of building to be included?
~Longeye~
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #39 on: June 30, 2013, 08:10:20 pm »
Blarg, just run into another prorblem after fixing config and connected for a bit, I thought I would check out the mining world and  then it kicked me saying Internal Server Error and does this every time I join. Help?
Augustus Longeye
Re:
« Reply #40 on: June 30, 2013, 09:08:30 pm »
Ah, the mining world might be a bug I introduced, ill look into that one!
~Longeye~
Piyok0
« Reply #41 on: July 01, 2013, 01:30:53 am »
There is a way to make steam boilers and such. Maybe a way to go?
« Reply #42 on: July 01, 2013, 01:47:19 am »
I'm thinking a huge Victorian factory looking building, and on the inside, is rows of steam boilers and whatnot.
Gunner Gregson
Hired Gun, Gunsmith
« Reply #43 on: July 01, 2013, 02:06:51 pm »
If your looking for renewable power you can opt for walnut farms and biogas engines.
walnut trees - walnuts - squeezer - seed oil - biogas engines- power.
would require no input from players, once its built, and would happily chug away on its own.
~GG
Ananias S. Wildwire at your service, for a price of course.
Major Vincent Smith
Eccentric Gentleman
jacknife98
« Reply #44 on: July 02, 2013, 08:15:14 pm »
I'm still stuck in the portal to the mining world, could we break it temporarily? I can't actually connect because of it.  Cry
« Reply #45 on: July 04, 2013, 07:25:06 am »
Who built the Asian pagoda? Is there anything underneath?
I decided I might as well make the chore of mining serve a double purpose, so I am tunneling from my base to spawn. Not sure why, but it seemed a good idea at the time. Anyhow.. I'll be passing underneath the Pagoda at level 50 if that's ok. From there on, it'll pass in front of the Bigass Castle and I'll surface it close to Uglyass Spawnhouse..
Augustus Longeye
« Reply #46 on: July 04, 2013, 02:22:32 pm »
Spawn house is dreadful, isn't it? Tongue
I still need to get round to moving it into the marble well!! It'll happen, promise Wink
Also Pea built the pagoda.... apparently it's full of brains, in typical Pea fasion.
So this communal build, what'll we go for? We can use solar panels and at LEAST one turbine to crank out blulectricity and I'd like a system whereby you can put a battery OR battery box into an ender chest and a few seconds later it'll come back fully charged.... I'm not sure if we have steam turbines as part of this build for IC, but if not we can set up some ultimate solar panels to do that. As for MJ steam boilers are probably the best idea, and the tree farm sounds like the best plan. That way we can probably also set up a "free logs" chest that can be filled.
As for style, why not make the whole damn thing a big airship? Smiley
~Longeye~
« Reply #47 on: July 04, 2013, 02:56:57 pm »
By the way: What happened to your infinite lava well, Longeye? Could that be incorporated into that system, something that gives infinite lava? Possibly linked to an age that is nothing but lava, never visited, only pumped out of?
« Reply #48 on: July 04, 2013, 02:57:42 pm »
Winning! It gets my vote.
And the lava idea sounds intriguing
P.S. There's nothing under the pagoda, feel free to dig away there Akumabito Tongue
Augustus Longeye
« Reply #49 on: July 04, 2013, 04:24:09 pm »
The lava well originally drew from the nether, but it lasted a lot less than I thought it would when we drained a huge spot. It can be done, and it can move, but that would be a right bugger to set up. To stop my own fail messing up people who drew from my well I was using lava fabricators and ultimate panels to make the lava, that could work if we were to set a load of them up.... I'd have to look into how quickly it can make the lava though.
~Longeye~
Pages: 1 [2] 3 4 5 6 7 8 9 ... 99   Go Up
Page created in 0.035 seconds with 16 queries.
