June 20, 2018, 02:51:20 am *
Author Topic: first use of Run'nBuff?  (Read 1290 times)
« on: February 18, 2013, 02:42:58 am »
Before I open the package anyone have advice for my first use of Rub'nBuff?
I will using it on flat black painted plastic squirt guns as a test piece.
« Reply #1 on: February 18, 2013, 05:03:57 am »
Start by using a very,very,very tiny bit-it can go a long way!
« Reply #2 on: February 24, 2013, 02:30:52 pm »
Well,that must have covered that.
« Reply #3 on: March 03, 2013, 09:31:33 pm »
I'm currently waiting for the cold can of black paint to warm up a
bit so I can spray a couple squirt guns and try it out.
« Reply #4 on: March 04, 2013, 03:21:51 am »
How long have you been waiting?!
Just toss it in a sink filled with warm water.
Ah,I see in another thread you've finished waiting and they're drying-good.
« Last Edit: March 04, 2013, 03:29:19 am by Drew P » Logged
« Reply #5 on: March 04, 2013, 04:03:28 am »
At this point I think that I prefer the dry brushing paint over the rub n buff....
Pictures later.
It will need another 'coat' of RubnBuff.
FichtenFoo
« Reply #6 on: March 26, 2013, 06:01:54 pm »
Also, you can thin it with mineral spirits/odorless turpenoid and paint it on as needed... even airbrush it, or so I'm told, but I've not tried that.
Thinned RnB with a sponge is also nice.
« Reply #7 on: March 26, 2013, 08:38:54 pm »
Wax based finishes tend to work best over slightly matt surfaces which give something for the wax to latch onto. On smoother surfaces it's a question of patiently building up very thin layers.
They tend to excel at bringing out both fine surface texture and deep, fine lines on flater surfaces the effect does indeed tend to be a lot more subtle than drybrushing, which can be better at 'forcing' metallic highlights on relatively flat curves.
Page created in 0.06 seconds with 16 queries.
