July 17, 2018, 07:25:39 am *
Author Topic: realistic brass finish on lead free pewter- tin  (Read 915 times)
BLOCKER
« on: October 31, 2012, 03:28:14 am »
hi, I need a realistic brass finish on lead free pewter, ive searched everywhere theres a few ways but i don't know which way is best
electro plating - seem abit tedius
acrylic metalic spray paint - need primer so takes the realism away from the metal
metalic permant marker
chromating - but thats yellow
I just need a simple relistic look which is fairly durable.. thankyou for anyhelp..
« Reply #1 on: October 31, 2012, 11:54:23 pm »
In terms of appearance and durability electro-plating is almost certainly the best bet.
The next best option would probably be a paint finish but there isn't really anything which will give a passably realistic brass finish straight out of the tin and a certain amount of time and technique is required to get a finish which isn't obviously a paint effect. Brass is particularly tricky to replicate as much of its character comes from quite subtle variations in its surface caused by oxidation.
Another possible option is to apply a satin lacquer, then successive thin coats of ink in various sheds of yellow and light brown to build up some tonal variation and then seal with a coat of gloss or satin lacquer.
Page created in 0.053 seconds with 16 queries.
