August 19, 2018, 10:22:59 pm *
Author Topic: Looking for pivot / screw on tube connectors ?  (Read 833 times)
4_0_4
Sweden Sweden
Hi Forest , hows Fanny?
« on: October 25, 2012, 09:33:53 pm »
I am trying to find some sort of T tube connector like this I just screw on  , a hinge joint connector ( ideally i can tighten / lock place ) and a pivot joint that will allow only left / right movement
 I was planning on using this with carbon tubing 22.2mm (ID) / 25mm (OD) or alternatively 26.5mm (ID) / 29.3mm (OD) , 28.5mm (ID) / 31.3mm ( depending on what is available )
you can see the whole range here
Has any one see sources for anything like this ( it can be anywhere ) ?
thanks
404
" You can lose every battle except that last " Sir Malcolm , Penny Dreadful
« Reply #1 on: October 26, 2012, 04:07:55 am »
The item in the image from Ehow can be found,obviously,in tool stores-mainly HarborFreight here in the US for pretty cheap.
Fineas Squidd
« Reply #2 on: October 26, 2012, 09:51:50 am »
Many boat and sailing yacht hardware suppliers have many different types of fittings like that.
4_0_4
Sweden Sweden
« Reply #3 on: October 27, 2012, 02:48:42 am »
Thanks guys ,
I managed to find a good supplier that has what Im after ( I think )
heres what I found for any one else looking.
One for the UK
And its counterpart in the USofA
These are the two best sources Ive been able to find so far.
4 4
 0
Page created in 0.066 seconds with 16 queries.
