March 21, 2018, 10:26:32 am *
Author Topic: Adding some gears to my Ipad case  (Read 1298 times)
« on: September 10, 2012, 03:03:39 am »
I am looking to add some gears to my leather Ipad case, but not sure how to do it. At first I thought of using screws but they would scratch the display and unsure as to how well glue would hold on leather. Any ideas or experience?
« Reply #1 on: September 10, 2012, 03:29:56 am »
Possibly E-6000?
« Reply #2 on: September 10, 2012, 05:11:38 am »
Personally my ideas and experience would say DON'T DO IT!  Cheesy
I'm kidding you do what you like. I was under the impression there were some rather funky gear themed cases available for iPad nowadays. That would probably be your safest scratch proof bet.
If you're set on real gears, there will be glue out there that will do it, but there is always a chance they will ping off I would imagine. The only other thing I can think of is possibly use small brass paper fasteners if the gears have a large enough hole in the centre, but you would probably want to glue some leather (or possibly thick tape or something) on the inside over the split shaft to prevent them from scratching.
Or of course you could try sewing them on, but that could also be tricky and possibly split the leather (as could fasteners without reinforcement).
« Last Edit: September 10, 2012, 05:19:50 am by Argus Fairbrass » Logged
Shadow Of The Tower
« Reply #3 on: September 10, 2012, 05:23:13 am »
Go ahead but you must watch this first:
Just Glue Some Gears On It (And Call It Steampunk)
« Reply #4 on: September 10, 2012, 03:52:13 pm »
E6000 should serve quite well. Be tasteful.
Page created in 0.054 seconds with 16 queries.
