July 17, 2018, 06:53:43 pm *
Author Topic: Help with a baggage aid!  (Read 1246 times)
abigailbeatrix
« on: May 14, 2012, 04:19:30 pm »
Hey everyone!
I aquired an awesome doctors bag in which I planned on keeping a lot of cool goodies. After a convention or two, I realized it's really not practicle for a small girl to carry around ~25-30 pounds in a bag for three days at a time.
While I could get super buff and deal with lugging my stuff around, I decided I'd make a cool little carriage for it. I plan on making a copper pipe base for it to sit on with small spoked bike wheels and attaching a cane to pull it around, but I want to go bigger AND better. I'm trying to figure out a way to have it elevate (like a small table) so I constantly don't have to bend over to pull things out of it.
This is where I need your help! I like the look of a scissor lift, but they tend to be really expensive and really big. I thought about making one myself, but I don't have the means to set up the hydrolics and actually make the cross-pieces on them. I've also looked into other types of folding tables, but because the base of the bag is pretty small (about a foot and a half long and a foot wide) and I want the bag to be waist high (probably around two and a half feet), the traditional folding legs won't work. I've also looked for telescoping legs, but I can't find them anywhere and even if I did, I wouldn't know how to attach them!
If any of you have a better idea on how to create a dolly with a collapsible table for this bag, I would love to hear it!
Unsubtle Pete
Discerning Scoundrel.
« Reply #1 on: May 14, 2012, 04:33:12 pm »
A scissor type arrangement is not impossible, if you are prepared to manually lift it into place - see clothes drying racks for what I am on about.
NEW Discerning Scoundrel blog
abigailbeatrix
« Reply #2 on: May 14, 2012, 04:46:08 pm »
I had looked into things similar like baby gates, but I am concerned about keeping it up with the weight. I carry a lot of liquids and my bag is pretty heavy. Do you think these drying racks could hold the weight?
Unsubtle Pete
« Reply #3 on: May 14, 2012, 04:55:54 pm »
Probably not. However it would not be too hard to duplicate the mechanism in wood or brass or steel.
abigailbeatrix
« Reply #4 on: May 14, 2012, 05:22:16 pm »
The reason I originally dismissed this idea was because I couldn't think of a locking mechanism. Do you think it would be possible to put in a couple brass pins or something to keep it from collapsing under the weight? I can't really think of anything else that could work.
Unsubtle Pete
« Reply #5 on: May 14, 2012, 05:30:47 pm »
Essentially, the lowest part of the mechanism must be prevented from moving laterally. A simple pin mechanism should suffice.
abigailbeatrix
« Reply #6 on: May 14, 2012, 05:53:15 pm »
I'm going to test this theory out this evening. I'll write back if it is a success or not!
Kittybriton
« Reply #7 on: May 16, 2012, 01:39:07 pm »
My thoughts on this potential project lean in the direction of something derived from a scissor jack of the  type often  found in an automotive toolkit. A length of theaded rod with a handle at one end, and two matched nuts to adjust the  spread of the base.  These could be mounted in a wooden pantograph, or a welded frame if you have a tame welder.
Professor Phineas Brownsm
« Reply #8 on: May 16, 2012, 03:02:58 pm »
should have one of these
Experimental Master Brewer - The Infamous Ginger Brau Emporium
abigailbeatrix
« Reply #9 on: May 16, 2012, 06:04:32 pm »
I hadn't thought about a scissor jack, but they aren't compact enough nor reach the height that I need. It's a good thought though!
Hah, only if I had little minions to cut in half for this purpose!
I ended up altering a laundry drying rack. I found one with metal joints and I will be making some additional supports out of copper tubing.
I'll post pictures when I am finished!
robotmastern
« Reply #10 on: May 16, 2012, 09:28:14 pm »
Or one of these
« Reply #11 on: May 17, 2012, 08:13:41 am »
Page created in 0.36 seconds with 17 queries.
