July 20, 2018, 06:15:58 pm *
Pages: 1 [2]   Go Down
Author Topic: HOW TO DRILL HOLE IN this piece.....???  (Read 3052 times)
hardlec
« Reply #25 on: April 18, 2012, 07:43:07 am »
Thanks for the clarification on drill speed.
A Dremal at Max speed is about 28000rpm.  Power drills go about 2000 rpm. Power drills have more torque. Hand drills are often a few hundred rpm,  so "fast" and "slow" can be subjective.
Whatever happens we have got
Both are true.
« Reply #26 on: April 18, 2012, 08:04:54 am »
 There are tables for calculating the appropriate drill speed for a given material and drill diameter
http://www.ultimatehandyman.co.uk/Metalworking/drilling_metal_technique.htm
It can also be calculated relatively easily once you know the appropriate surface cutting speed for the material in question.
Linear cutting speed = rpm x drill circumference.
« Reply #27 on: April 18, 2012, 10:46:23 am »
Check out jewelers supplies as well.  Rather than drilling you might consider a punch system like punch pliers for round or even square or oval holes.
I have a screw down hole punch and it works well but I don't know if it would fit in your shapes or what gauge they are.
The advantages are a neat hole, no danger of a bit snapping and brass confetti.
« Last Edit: April 18, 2012, 10:48:33 am by Hez » Logged
robotmastern
« Reply #28 on: April 19, 2012, 09:23:24 am »
Punches can however leave a large dent around the hole if you arnt carefull
Pages: 1 [2]   Go Up
Page created in 0.085 seconds with 17 queries.
