March 22, 2018, 03:07:28 pm *
Pages: 1 [2]   Go Down
Author Topic: Coker Cycles is bringing back the Wheelman 36" Ordinary!  (Read 5861 times)
Clym Angus
Lord of Misrule
« Reply #25 on: September 09, 2015, 11:25:18 pm »
Just an update, you can get the single-speed, unicycle-wheeled Wheelman from Coker now for a cool $900:
Impressive unicycles too. They have quite the selection when it comes to choice. Nice to see you Mr P.
« Reply #26 on: October 23, 2015, 12:14:22 am »
I just found a picture of a regular 3 gear hub. Let me see if I got what Narsil is saying:
Instead of the frame holding on to the ends of the axle, it holds on to the sprocket. The ends of the axle will have the cranks and pedals. That leaves the little chain that changes the gears to be placed somewhere else. just don't have a sprocket and chain, the crank is directly attached to the shaft where the sprocket would normally go. A chain/sprocket drive doesn't reverse the direction it just translates the torque from the pedals back to the rear wheel. In a unicycle or front wheel drive bike the pedals are already on the same axis as the drive axle but not much else changes apart from the way  that the pedals are mounted to their axle.
Pages: 1 [2]   Go Up
Page created in 0.024 seconds with 15 queries.
