August 16, 2018, 06:10:49 pm *
Author Topic: UN-embossing ( even possible? ) or... The rambling of a undertaxed mind  (Read 971 times)
« on: February 16, 2012, 08:17:30 pm »
I had Spaghetti and meatballs for lunch today... I reached into my desk and pulled out an Altoids tin
and thought to myself "too bad the lid has Altoids embossed into it...." i have a bunch of those lying
around cluttering up my shop.... I could make them into......... ( not to mention they are fairly cheap
to buy new.... but that is not the way my brian works )
Then I wondered if it would even be possible to 'un-emboss' something.... ( probably not )
and then while typing this out ( with my fresh minty breath ) the thought occured to me.... ' I could just
etch a small brass plate and affix it over the embossed name.....Oh hey, another reason to try etching out!'
Clearly, I need a more mentally challenging job......
Lady Chrystal
Lady Adventurer, Chronicler
« Reply #1 on: February 16, 2012, 08:20:13 pm »
You could beat the design out, hopefully leaving an irregular bevelled effect.
Or at least have fun trying!
« Reply #2 on: February 16, 2012, 08:24:37 pm »
It is possible to some extent. The problem is that when the metal is stamped it also stretches so you end up with a larger surface of slightly thinner metal and shrinking sheet metal is much more diffcult than stretching it.
However if you smack it with a hammer onto a suitable flat surface eg a block of wood then you should at least be able to get back to a more or less flat surface, although hit may not be all that pretty and might be best being covered somehow.
« Reply #3 on: February 16, 2012, 08:40:55 pm »
Yeah, I just need a tiny hammer and a little anvil...... lol
My anvil is Harbor Freight 'ASO' ( anvil shaped object ) and is not completely flat on the face anymore...
I use an Altoids tin for making my charr cloth for a flint and steel fire starting kit and tossing it in the fire
gave me an interesting color once it was done.... an etched brass plate riveted ( tiny rivets ) to the lid
would be a great contrasting color
( see here for details - http://www.bushcraftusa.com/forum/showthread.php?t=1001 )
« Reply #4 on: February 18, 2012, 06:01:46 am »
Slightly dome the lid using a shaped end of 2x4 or similar wood.  That way you would not have to shrink the plate but stretch all of it (much easier) while the stock of your wooden "anvil" will hold the shape of the sides so that the tim still closes.
It works in my head.  No idea how difficult it would be in real life.
Page created in 0.044 seconds with 17 queries.
