May 21, 2013, 10:18:51 am *
Author Topic: Avatar image  (Read 659 times)
TVC15
« on: August 29, 2011, 01:34:30 am »
My avatar image reverted back to an older one. I've tried to correct it in the profile section but seem to not want to take it. Some help on what's going on or what I'm doing wrong. Thanks.
Lady Chrystal
Lady Adventurer, Chronicler
« Reply #1 on: August 29, 2011, 01:56:46 am »
First thing to check - is your new image below the max size? I had problems until I'd reduced the file size sufficiently.
TVC15
« Reply #2 on: August 29, 2011, 01:58:42 am »
The size should have been okay since it was showing on my posts for two weeks straight. And then without warning it 'defaulted' back to what you see now.
Major Willoughby Chase
Awesomologist
« Reply #3 on: August 29, 2011, 11:31:51 am »
As I've said to people before who are having this issue, could you post the image you're trying to upload here please?
TVC15
« Reply #4 on: August 30, 2011, 05:27:25 am »
It seems to be working now while I'm on my home pc. Tomorrow will check work pc to verify.
Awesomologist
« Reply #5 on: August 30, 2011, 09:34:38 am »
Ah in which case it's the same as the last person who asked, I suggest you do a forced cache refresh Ctrl + F5.  You avatar did change, it's just that your computer saves time by storing some website images on your computer, so it kept using:
http://brassgoggles.co.uk/forum/user-avatars/avatar_17417.png
That image address will remian the same (apart from the image extension), when you change your avatar, unless your cache is refreshed (automatically by the PC, or manually by the user).
TVC15
« Reply #6 on: August 30, 2011, 05:18:21 pm »
Thank you, Major. I'm sure the work pc will show the correct avatar and if not, will know how to remedy the situation.
inigo jameson-gatling
Iceland Iceland
lofthussar
« Reply #7 on: September 03, 2011, 11:02:27 pm »
Thank you Major. I was having the same problem and ctrl+F5 worked for me. I now have a picture of me (vainity rules) rather than Jón Sigurðsson. Though if there are complaints, I will change back!
You cannot complain about the sky if you suffer airshipwreck for the second time.
Dr Fidelius
« Reply #8 on: September 16, 2011, 07:32:21 pm »
sig test, please ignore
Angelica Needle
Navigator & Mechanic: RD Susurrus
« Reply #9 on: November 17, 2011, 10:20:10 am »
Avatar test: Also having avatar problems
Edit: All fixed. My problem was that I changed my sig, and it removed my avatar. I tried to load the original picture I used, but it kept restting without the pic, and no info as to why. From the posts here, resizing worked.
« Last Edit: November 17, 2011, 10:25:50 am by Angelica Needle » Logged
The sound of the gentle rattle of china cup on china saucer drives away all demons, a little-known fact.
Terry Pratchett, Snuff
Page created in 0.105 seconds with 18 queries.
