chicar
« Reply #350 on: December 12, 2009, 02:25:55 am » |
Yup, just repair it.
I prefer be king in hell than slave in heaven, but being king in heaven would be much,much, better.
He sent a messenger to the other bride, and asked her to return to her own kingdom, for, as he informed her, he already had a wife,and someone who had found an old key did not need a new one. -The Twelve Huntsmen, Brother Grimms.
"Atheism is so senseless. When I look at the solar system, I see the earth at the right distance from the sun to receive the proper amounts of heat and light. This did not happen by chance." Sir Isaac Newton
Joozey
« Reply #351 on: December 18, 2009, 10:18:26 pm » |
Engineer J. Fairbeard, Civil Engineer Designer of the H.M.S. Mercuria
Drake White
« Reply #352 on: December 20, 2009, 10:00:29 pm » |
Here's what I'm using at the moment.
« Reply #353 on: December 22, 2009, 12:50:34 pm » |
Excellent! did youi create that yourself?
S.Sprocket
Administrator
 United States
Industria Proficiscor In!
« Reply #354 on: December 24, 2009, 01:58:32 am » |
I'm really glad to see this thread still going strong. I'll be working on some visuals tonight. Maybe I'll have something to show off by Sunday
"It's what a cove knows that counts, ain't it Sybil? More than land or money, more than birth. Information. Very flash." -Mick Radley
kurohone
 Canada
« Reply #355 on: January 02, 2010, 04:26:23 pm » |
Whoa. What's going on there? What OS/Widgets/etc do you ahve going on there? I love it! On my own desktop, I'm sad. I didn't get around to designing the antique thermometer/barometer I had hoped for over Xmas.
Zwack
« Reply #356 on: January 03, 2010, 07:27:15 am » |
Full size of my desktop... I'm using the Human theme with the steampunk pointer set (from e17-stuff.org) and a custom background. For Firefox I'm using the Walnut theme. Z.
"At least those oddballs are interesting" - My Wife. I'm British but living in America. This might explain my spelling.
yetiboy
 Canada
« Reply #357 on: January 07, 2010, 05:39:12 am » |
I thought I'd join in the fun. I'm new to the forum, but this thread has given me a lot of inspiration. I've used an animated gif posted by someone earlier in the thread (unfortunately the resolution isn't as high as my settings, so it's slightly blurred - if anyone has a higher res version, I'd love it) and I've used various icons from various sources. the Pathfinder and Firefox icons are my own creations. The story I've included in the background image is part of a steampunk story called Steampunk Yeti Hunt by BonnySaintAndrew that I found. I've altered it slightly using GeekTool to include the current time, date and weather (including image) here at home (in the info from the first journal entry) as well as iCal info with upcoming events and my ToDo list at the bottom of page 2. iTunes info shows up as well, but only if it's running. Blends right in  It's going to take a while, but eventually all my icons will be changed - a lot to change though! yetiboy
Wisconsin Platt
« Reply #358 on: January 07, 2010, 06:03:23 pm » |
Yetiboy - Excellent use of Geektool!
Well done.
┌─┐ ┴─┴ ಠ_ರೃ
yetiboy
 Canada
« Reply #359 on: January 13, 2010, 05:09:52 am » |
I'm having an issue with folder icons, and I'm wondering if anyone else has run into this.
I'm trying to change some folder icons, but if they're aliases they don't change - regardless of whether the folder icon they point to is changed. Anyone else encounter this and figure it out?
yetiboy
Zwack
« Reply #360 on: January 13, 2010, 05:15:42 am » |
By Aliases I assume that you mean symbolic links... The thing is that if you are changing a folder, a Symbolic link is not that folder. You would need to change the properties of the symbolic link itself. (I'm making assumptions of the underlying Unixlike mechanisms being used in MacOs here...)
Z.
 Canada
« Reply #361 on: January 14, 2010, 05:10:47 am » |
Actually, just to be confusing, OSX supports both Aliases (akin to Windows Shortcuts) and symlinks, and the two behave just slightly different from one-another (at least, in Tiger they do). For instance, Finder displays, and treats, folder aliases and folder symlinks as interchangeable — double-click on either one, and you open the folder that the alias/symlink points to. On the other hand, Terminal will happily cd into a symlink, but try to cd into an alias and you get a resounding "WTF?"
Back to yetiboy's question: I just did a small experiment. I created a folder, applied a custom icon to it, then created an alias (⌘L) and a symlink (ln -s). Both inherited the custom icon. I then changed the icon on the original folder; the Finder icon on the symlink changed (when I clicked on it), while the one on the alias did not.
It probably has to do with the fact that aliases (inherited from Classic, introduced sometime around System 7) are HFS file objects and so have always had their own icons, while symlinks (inherited from the NextStep/BSD Unix branch of the family) are UFS file objects which have never had their own icons, so (I'm guessing) Finder "fakes it" by using whatever the referent file's icon happens to be at present.
Hope that's of some use.
By the power of caffeine do I set my mind in motion By the Beans of Life do my thoughts acquire speed My hands acquire a shaking The shaking becomes a warning By the power of caffeine do I set my mind in motion The Leverkusen Institute of Paleocybernetics is 5838 km from Reading
FreeBooteR
 Canada
« Reply #362 on: January 16, 2010, 04:21:43 am » |
Thanks Araneas, great DR17 theme. Changed mine some. Working on a new conky but this karamba theme on the desktop works well too.
Omalleh
« Reply #363 on: January 19, 2010, 10:52:33 pm » |
My attempt at a minimalist Steampunk desktop: And a slightly less steampunk, but old looking desktop: (Yes, they are both pretty much the same, but with a different background)
kasei
 Denmark
....oh...ya see, now I've broken it.....
« Reply #365 on: January 29, 2010, 10:29:50 pm » |
sorry for reviving an old thread, but I was transfixed with it as soon as I saw it and had to give some of the hints tips and links I found here a try. So far, this is what I have come up with: My desktop My desktop with start menu and winamp open How my intertrons looks now: Thanks to everyone here for the awesome ideas! So very inspirational. Now I think I will spend tomorrow browsing through freesound.org collecting some steampunk-esques sounds to go with it all. What a fun first day I have had on this forum
woodguy32
« Reply #366 on: February 05, 2010, 01:39:59 pm » |
 My old desktop in the workshop...lol...one of my many gearless thinking devices...need to get some better pics..
Builder of Old Wooden Cars..Hot Rod Woodie Wagons
The Woodie Works
mattig89ch
« Reply #368 on: March 25, 2010, 11:24:39 pm » |
Thanks Araneas, great DR17 theme. Changed mine some. Working on a new conky but this karamba theme on the desktop works well too. My word Old boy, thats brilliant! What OS is that? Ubuntu?  My old desktop in the workshop...lol...one of my many gearless thinking devices...need to get some better pics.. Jolly good looking machine. Its seems you've copied the steam punk workshop's keyboard and desktop quite nicely. Doesn't look very powerfull though, if I may aks, what are you running (hardware wise)? Edit: For all of you firefox users, check this out: https://addons.mozilla.org/en-US/firefox/addon/8890
« Last Edit: March 26, 2010, 01:59:55 am by mattig89ch »
I believe that Steampunk is more than just brass and watchparts. It's finding a way to combine the past and the future in an aesthetic pleasing way. It's living a life that looks old-fashioned, yet speaks to the future.
Edwin Barrett Mudgewhack, at your service
Hikaro Takayama
« Reply #369 on: March 26, 2010, 03:21:42 am » |
Not super-duper steampunk... More Dieselpunk than anything (I was going for a WWII/1950 computer look without getting too fancy):
"It is by steam alone that I set my contraptions in motion. It is by combustion of coal and boiling water that the engines acquire speed. For protection, the eyes acquire goggles, The goggles become a warning. It is by steam alone that I set my contraptions in motion."
abney
 United States
« Reply #370 on: March 29, 2010, 10:37:58 pm » |
I know not the most exciting display of wow... but here you are!
Noninimicus
 United States
Quando Omni Flunkus Moritati
« Reply #371 on: April 01, 2010, 11:28:41 pm » |
My Desktop (For this week anyway):
Wisconsin Platt
« Reply #372 on: April 09, 2010, 08:12:56 pm » |
I know not the most exciting display of wow... but here you are!  I like it. Minimal.
« Reply #373 on: April 10, 2010, 02:22:52 pm » |
Here's mine:  Wonderfully stirring I must say when it first comes up.
thebnf
« Reply #374 on: April 10, 2010, 07:39:36 pm » |
 my current wallpaper, which was a doodle i decided to touch up a little.
