January 22, 2018, 01:36:34 am *
Author Topic: Need a portholes for your occult study instruments ?  (Read 2178 times)
chicar
Chicar556
« on: May 30, 2011, 02:52:30 pm »
Maybe this can help:
Infinity Mirror Illusion!DQ
Dr von Zarkov
<Maddest Scientist>
« Reply #1 on: May 30, 2011, 04:11:46 pm »
This circular infinity mirror would be perfect behind a 5-leaf iris shutter.
– Loren Eiseley
« Reply #2 on: May 30, 2011, 04:20:49 pm »
I wonde,r if you used two offset rows of LED's instead of one, would you get a spiralling tunnel effect?
« Reply #3 on: May 30, 2011, 08:27:13 pm »
I don't think so; I think you'd just get a sort of wave pattern. Interesting idea, though.
Danbury Shakes
« Reply #4 on: May 31, 2011, 01:59:10 am »
you'd get two set of rows of offset lights.
edit
however if you added some electronics to get each row to flash on  and off in sequence you could get some effects
« Last Edit: May 31, 2011, 02:02:18 am by Danbury Shakes » Logged
Visit my Facebook page Jason's Gems Jewellery at jasonsgemsjewellery
or my website Jason's Gems
« Reply #5 on: June 07, 2011, 08:59:27 am »
hmmm desktop stargate anyone?
« Reply #6 on: June 07, 2011, 09:08:50 am »
edit
Hmm, or two rings of LED's, turning in opposite directions.. could be interesting..
A.K.A. Scanner Camera Builder
« Reply #7 on: June 07, 2011, 09:45:37 am »
you can have the rear mirror slightly off parallel to create a bend. Rotate this mirror and you have a rotating bend.
When you do this effect with camera and tv screen you have a small delay. Having flickering leds can create the lights going into the tunnel.
You can also make the rear mirror a seethrugh mirror and place an object behind this mirror. When you illuminate the object, it shows trugh the mirrors. Creating the illusion of the object inside a endless tunnel.
But to my knowledge, there is no way you can make the lights spiral down the tunnel.
darkshines
Miss Katonic 1898
« Reply #8 on: June 07, 2011, 09:55:57 am »
Interesting. Mr C pulled this bad boy out of a skip, and I would LOVE to make it into an occult study instrument....
« Reply #9 on: June 07, 2011, 10:06:14 am »
I had a string of xmas lights with a controller so it could flash in a few different patterns.
I made an xmas sign for a buddy of mine who is into oldsmobiles. it says "64 olds Xmas"
it was a real pita to divide up the lights for all  the letters and put them in an order so the would flash properly, and hide all the extra wire. I drilled a butload of holes and still managed to end up with two extra lights (which I just stuff under the board with all the extra wire)
it's old school bulbs but changing them out isn't all that hard unless you manage to drop the socket under the board.
the new LED style should be much easier to work with.
oooh nice find, Darkshines, but be careful of the HV circuit. you can mount a computer screen in there for effect. is that paint all over the cabinet? pity but if its latex you might be able to get it clean without ruining the finish too much.
what if you use mylar film for the back mirror? you could deflect it and bulge it with air pressure, maybe even make it ripple.
Pivole
Salvum Terram Meam!
« Reply #10 on: August 20, 2011, 08:38:37 am »
Is there anywhere that I can find written instructions for this?
Fellowship is life!
Captain Shipton Bellinger
« Reply #11 on: August 22, 2011, 04:49:15 pm »
Instructables is generally a good starting place for this sort of thing.
Page created in 0.076 seconds with 17 queries.
