January 18, 2018, 09:19:23 am *
Author Topic: Pocketwatch Help  (Read 1041 times)
Xzavier_Heterodyne
« on: August 24, 2010, 12:02:35 pm »
I recently puchased a (currently) non-working mechanical pocketwatch (i purchesd it knowing it did not work, it was £28).
I have had a look inside and the spring appears to have moved, (I thought i noticed a hair in the mechanism, upon examination with my loupe and apai of tweezers it was part of the spring that had unwound?)
I am just wondering if this should be expensive to get repaired? I have already been quoted about £80
I hope this makes sense
Pike
Failed the Turing Test
pikestaff
« Reply #1 on: August 24, 2010, 01:56:19 pm »
Is it a newer or older pocketwatch?  And which spring are you referring to?
Pictures of the movement would be helpful also... although seeing as you already got a quote I would probably just go with that, assuming said person is knowledgeable and took a look at the watch already.  (Of course, I still want pictures, because I am a geek like that... *cough*)
« Last Edit: August 24, 2010, 02:10:02 pm by Pike » Logged
"The law of entropy has been losing steam lately..."
Xzavier_Heterodyne
« Reply #2 on: August 24, 2010, 04:18:50 pm »
from the design on the outer back cover it appears to be Art Deco, but i could be wrong.
the main spring? the one that tightens when you wind it
will try to get pics. I hope they are knowledgeable (i enquired at timpsons, they do watches and shoes ect)
« Reply #3 on: August 26, 2010, 05:57:40 pm »
80 sounds like a decent price for a general clean and service; they must not have thought there was much wrong with it.  For a simple mechanical lever watch, I tend to see between $50 and $150 for a basic service, depending on where exactly you live.  But make sure you're dealing with an actual watchmaker!  If the place that quoted you doesn't have a watchmaker "on site", you're better off finding a real watchmaker to look at it.  Some places have very interesting definitions of "clean and oil", but if it doesn't involve a complete dis assembly of everything, it isn't a proper job.
Xzavier_Heterodyne
« Reply #4 on: August 27, 2010, 10:51:58 am »
Thanks Abslomrob, they don't have one on site, I'll look for somewhere that does.
Prof Thadeus Q. Wychlock
What Watt ?!
« Reply #5 on: September 06, 2010, 10:35:05 pm »
@Abslomrob @Xzavier_heterodyne
I'd have to agree with Rob.
I'd try and find a proper watchmaker.
The price is about right but the place .......... I'm not so sure.
A good way to tell is the waiting time.
The jewellers here have a 2 - 4 month waiting list on mechanical watches - because they have an excellent reputation.
Just my 2p  Smiley
Page created in 0.024 seconds with 17 queries.
