July 22, 2018, 10:33:21 am *
Pages: 1 [2]   Go Down
Author Topic: Must Have Tools  (Read 5433 times)
hardlec
« Reply #25 on: January 27, 2011, 02:37:22 am »
Those cutters look like they will flush cut wire....
Will they?  If so I will be about getting a pair post haste.
Whatever happens we have got
Both are true.
torkbox
« Reply #26 on: January 27, 2011, 03:45:51 pm »
They cut cleanly but not flush. You would need, ahem, flush cutters for that. These crosscut and may leave a slight burr.
roadrdr6
« Reply #27 on: February 05, 2011, 06:11:20 pm »
I don't anyone mention this, and apologies if they did.  If you are working with copper or brass pipe, a pipe cutter is essential. This site shows a number of differ sizes and styles:
http://www.acehardware.com/family/index.jsp?categoryId=1260857
Yes, you can cut pipe with a hack saw or any number of tools, but pipe cutters cut quick, clean, and with almost no effort. Ask any plumber if they are ever without them.
With highest regards,
Rufus T. Firefly, Esq.
« Reply #28 on: February 17, 2011, 02:13:31 pm »
Life is not complete without:
Plasma Torch
Acetylne Torch
Mig Welder
Auto on Helmet
Leather gloves
right angle hand grinders (lots of hand grinders)
Artfagdirtbug
« Reply #29 on: March 08, 2011, 08:28:11 am »
I work primarily in steel and to a lesser extent, wood. The tools that get the most use in my shop are:
Oxy acetylene rig with cutting and brazing tips
Anvil cut from railroad track, bench mounted with 6x6 post running to the floor directly underneath
Bench grinder
Combo belt/circular grinder
14" chop saw with metal cutting blade
8 inch chop saw with wood blade
4" angle grinder
Dremel multi tool with cutting wheels and grinding/sanding bands. Pays for itself every day
Smooth faced 2 lbs. hammer
Tongs and pliers for handling and bending hot metal
MIG welder and auto darkening mask
Files
Wire brushes of both steel and brass
Happy building!
Veritas
« Reply #30 on: March 09, 2011, 03:57:17 am »
Just a few of the tool I consider "necessary" as a watchmaker/beginning engraver.
SteamFreak
« Reply #31 on: March 09, 2011, 06:40:07 am »
Two part post:
1. I do some wood turning when the mood strikes me. mostly I make pens. these are the tools I couldnt live without:
-Mini lathe
-Standard gouges
-Mini gouges for detail work
-Sandpaper
-Shotgun patches (for applying finish)
-Wax bars (for finishing)
-7mm mandrel
Part the second. I was wondering what I would need for (very) basic leather working tools. I plan on making my own goggles some time in the near future and I'd like to do it right. I have needle and thread for thinner fake leather because I also do a little sewing (very little)
« Reply #32 on: March 09, 2011, 07:09:20 pm »
Two part post:
-Mini lathe
-Standard gouges
-Sandpaper
-7mm mandrel
For simple leather working these are the basics
essential :
-Needles (needles for  hand stitching leather have small heads and rounded points)
-Awl (leather work awls should have a blade with a diamond shaped rather than round cross-section)_
-Sharp knife or leather shears
-Linen thread or synthetic alternative
-Beeswax for coating thread
-Various grades of sandpaper for finishing and smoothing edges
-dyes, conditioners and polishes
useful :
-Rubber based contact adhesive; not a substitute for stitching but useful for holding parts together while you work.
-Stitch wheel or pricking irons; for marking out regular stitch holes
-Stitch groover. carves a shallow line at a set distance from an edge, helps to keep stitching straight and protected from abrasion.
-Red pencils for marking out, red is the colour most easily hidden by dyes.
-Punch; for making holes for thongs etc
-snap fasteners, rivets and tools for setting them
-gum tragacanth for sealing edges
-spring clamps
Additional:
-selection of tools (eg wax carving tools) for embossing and carving
« Last Edit: March 12, 2011, 02:23:56 pm by Narsil » Logged
SteamFreak
« Reply #33 on: March 10, 2011, 12:58:11 am »
You have been most helpful Narsil Smiley
hardlec
« Reply #34 on: March 15, 2011, 03:18:26 am »
Harbor Freight is now selling a rather nice wooden tool box for a decent price.
Must have a tool box, why not one with some style?  My Grandfather left me his.  He was a tool and die maker at Westclocks, when they made clocks with clockworks.  It is at least 60 years old, and is a work of art in itself.
Miles (a sailor)Martin
Just a head full of random thoughts
« Reply #35 on: May 24, 2011, 11:23:35 pm »
just a note . the H.F. wooden machinist chest .
                       a few things to keep in mind;
                   a. the doors are loose on the slides,  no stops
                   b. the chest is bare wood, no finish has been put on them
                   c the wood is a soft wood, so do not drop it
                   d the drawers have a tendency to bind,
in comparison to a Gerstener , not in the same park, but much more affordable for most.
got one for my sister to use as a jewelry box. yes she has that much costume stuff.
                                                  miles
Who you calling old, Sonny boy? Just because my birth certificate is on birch bark there isn't any reason to be calling names.
machinist for hire/ mechanic at large
Warning : minstrel with a five string banjo
Pages: 1 [2]   Go Up
Page created in 0.166 seconds with 18 queries.
