May 30, 2020, 09:29:15 am *
Author Topic: A good paper for the toner transfer method  (Read 7566 times)
« on: January 02, 2010, 02:24:40 am »
For everyone that is looking for a good paper for transferring toner images, here is photographic proof that the backing of Avery brand peel-and-stick labels works great:
Uncut sheets printed on a HP laserjet printer. This is the front of one piece and the back of another.
cut piece on the brass. The purple paper is a piece of card stock to act as the carrier through my laminator.
After 10-15 trips through the laminator, the Avery paper peels right off (no soaking) and leaves a great image.
I follow this with green foil from pulsar and go to the etch tank…
alfa1
« Reply #1 on: January 03, 2010, 12:06:13 am »
Just to clarify - are you saying that you print the image on the back of the sheet, not the label side?
« Reply #2 on: January 03, 2010, 05:37:51 am »
I peel all of the labels off and print on the exposed wax paper, not the back of the sheet.
Page created in 0.067 seconds with 17 queries.
