January 22, 2018, 07:29:57 am *
Author Topic: How to seal a steamed USB key at the connector?  (Read 1106 times)
Gozdom
Hungary Hungary
« on: December 27, 2009, 12:27:19 pm »
I've made a flash drive casing. It was pretty straightforward, the main component being a somewhat flattened brass pipe etched, ornaments etc. I have made wooden plugs for each end. But how do you make the plugs for the connector (and cap) side? I understand it can be made the same way, drilling and dremelling out the square hole, but seems like a lot of work. Eventually, I used modeler's putty which was painted black. Any ideas?
Absinthe Dreamer
What is hidden in an empty box?
« Reply #1 on: January 03, 2010, 10:29:45 pm »
You could try taking a female USB connector apart and using the metal socket and build the end plug around it. You could use the modeler's putty to cement it into place.
Remember Feldstien's Law - Never, ever play leapfrog with a unicorn.
Page created in 0.023 seconds with 17 queries.
