January 21, 2018, 02:07:24 am *
Pages: 1 [2]   Go Down
Author Topic: Book binding tutorial (the simple way)  (Read 9377 times)
Dorian Ambrose
« Reply #25 on: May 29, 2011, 05:51:12 pm »
Thank you so much for explaining in an easy way bookbinding! I've had a desire to give my hand at it, but wasn't sure where to start. What sort of paper do you recommend? I'd prefer something that would look old/worn while still being sturdy. Ultimatly what in thinking of making a "field book" for noting and sketching on (like a jungle botanist!)
For that purpose, I would use Linen/cotton paper. It is generally very crisp and strong and unlike regular cellulose based paper, it is almost unaffected by water.
This is the stuff used to print paper money and as most of us know, a banknote will easily survive a spin in the washer.
I would also advise the use of high quality pigment ink. Like the paper, it is almost entirely unaffected by water, so the combination should be perfect for outdoor use.
As an added protection, you can leave the overhanging cover material (pics 6, 7 & 8 in original post). Cut the corners as shown but do not fold them over or glue them down. Instead of gluing the first page to the cover as shown, glue one piece of fabric to both the first page and the cover and to the overhanging cover material.
When finished, this will give you little leather flaps on the sides of the book, that can be folded to cover the otherwise exposed edges of the pages.
I have done this myself and also seen it on a few notebooks of older date. It works great and looks good.
What kind of thread would be best to use?  What if I use thicker pages, like home-made/natural papers?
Any will do, really.
I would stay clear of the polyester/nylon/etc. types, as they tend to cut the paper more than natural fibers.
I like linen, but also have silk thread of various types. I am not a fan of cotton, since it is just not as strong as linen.
Silk would actually be a perfect choice for the field book mentioned above. It is strong and does not rot.
Flightless Phoenix
« Reply #26 on: July 25, 2011, 02:55:00 pm »
Thank you, a thousand times thank you.
I've made some notebooks in the past and have been searching for a clear book binding tutorial for many a year now. T
his is exactly what I needed. I am forever in your debt.
cemeteryresearcher.com
*gremlins permitting
Lady Ava
electrogirlak
« Reply #27 on: July 28, 2011, 05:49:10 pm »
Such a good tutorial, made one for LYM and it looks like it'll last a substantial amount of time! Cheesy
Mahogany
« Reply #28 on: August 04, 2011, 12:58:09 am »
Just did my first attempt at making a book.
Here's a tip for everyone: Glue bleeds through fabric.
I used one of the heaviest fabrics I have but even that wasn't enough.  I ended up putting on another outter casing, not gluing the front and back, just the edges, and then glue down the first and last page - well, technically the second and second to last page, seeing how I already glued down the first and last page.  It worked!
Thank you again for posting this!  My auntie's going to love this. ^_^
Edit: Sorry, just remembered.  I tried putting five papers together at once, seeing no need to only have two together in one bundle.  Now I see the reason.  It comes out all sloppy with so many together.  I'm sure there are other ways of doing it to make it work, but yeah, in the future, I'm sticking to the two or three pages per bundle.
« Last Edit: August 04, 2011, 08:16:20 am by Mahogany » Logged
LukeHogbin
Slovenia Slovenia
Steamcat
« Reply #29 on: August 04, 2011, 01:25:18 pm »
With 80gsm paper (your ordinary xerox/printer paper) pre-cut to A4 sheets, I usually stick to signatures comprised of 2-3 sheets folded to A6. Tends to work fine. Then again, having access to a proper trimming guillotine has its benefits.
sweetieg_227
« Reply #30 on: August 28, 2011, 03:28:45 am »
And... Robin Hood: Men in Tights? That film is awesome.[/quote]
I agree! Cheesy
Pages: 1 [2]   Go Up
Page created in 0.153 seconds with 17 queries.
