February 09, 2012, 06:23:01 pm *
Author Topic: News from the shoggy shack - projects in the work  (Read 1084 times)
Tinkering for its own sake
« on: November 09, 2009, 05:34:43 am »
First project: Brass goggles. 52mm brass tubing, normally used to build boilers for toy steam engines, is the base. The screw rings of German welding goggles are glued to the tube with J-B Weld (heavy duty two-component epoxy). The nose bridge will be replaced with a combination of screw rod and brass tubing, a keychain will become the headband. That's a prototype. If it works out great, I might be tempted to make a series of brass goggles.
Second project: Respirator. A standard mask (two filters, covering nose and mouth) will receive old Russian gas mask hoses that can be connected to a backpack unit. If everything works out fine, the mask will retain its filtering abilities. Embellishment with brass scales is planned.
Third project: lighting. 45 amber coloured LEDs will become a domestic lighting solution. Add to that mix a stabilized 12 volts power source and a bunch of resistors. I know how to do it, I just need to wait for the supplies. I just don't know yet how it will look.
Lucius Voltaic
I need a cup of the brown stuff, shade of an acorn
LuciusVoltaic
« Reply #1 on: November 10, 2009, 08:57:12 am »
Ooh, sounds interesting!
...is that the same tubing that you're trying to sell off your surplus of in Trading?
"The man who is clever and lazy however is for the very highest command; he has the temperament and nerves to deal with all situations."
--General Baron Kurt von Hammerstein-Equord, clearly talking about me.
« Reply #2 on: November 10, 2009, 03:18:33 pm »
Nope. I ditched the copper tube idea. If I had cheap access to that length of brass tubing, I'd be in tinkerer's heaven.
« Reply #3 on: November 11, 2009, 10:49:01 am »
My little lighting solution. Clusters of five amber-coloured LEDs, nine of them.
Lucius Voltaic
LuciusVoltaic
« Reply #4 on: November 12, 2009, 07:36:48 am »
Ooh, that looks rather opera-house. Get some frescoes going on the walls, a few half-columns, and you're golden.
« Reply #5 on: November 15, 2009, 03:33:10 am »
Dr. Lemure
Lemure~ phantom, ghost; Lemur~ cute, fuzzy primate
« Reply #6 on: November 15, 2009, 08:53:14 am »
Ooh, very snazzy! Clever way to connect the goggles so the respirator wouldn't bump into the nosepiece. Cheesy
Blow wind! Come rain! Our zeppelin fleet cannot be slain!
« Reply #7 on: November 18, 2009, 06:06:10 pm »
Some closeup pictures of the goggles:
Der Tinkermann
brosiman
« Reply #8 on: November 18, 2009, 09:01:00 pm »
Some very nice work,herr elShoggotho
« Reply #9 on: February 19, 2010, 05:08:19 am »
A mystery shot. Find out what is what.
Everett R.I. Krowley, III
Federal Bountyhunter and Investigations Agent
« Reply #10 on: February 19, 2010, 08:56:32 am »
I am certainly curious as to what that mystery shot is!  I've long wanted one of those "field" phones you've got strapped up there.
and that looks like an arcade controller next to it, with the red buttons
Achrist
Belgium Belgium
« Reply #11 on: February 19, 2010, 12:11:33 pm »
Das ist ein Fernspecherwachskerzenlaterneflaschenholzbrett Gerät ! Na.. hab ich recht ??
« Reply #12 on: February 19, 2010, 02:14:17 pm »
Eine elegante Vermutung, aber nicht ganz richtig. Das sind mindestens vier Projekte, zwei davon fertiggestellt.
An elegant guess, but not exactly right. These are at least four projects, two of them finished.
Hikaro Takayama
In Pennsilfaanish Deitschland
« Reply #13 on: February 20, 2010, 04:48:59 am »
That was close to what my guess would have been (A telephonicgamecontrollerlanterntesttubestand), but since it's 4 projects, then:
It's a modified "Spirit of St. Louis" "Aircraft" telephone (I have one of their "Aviation Field Phones" but am not that happy with the overall quality of it, however it has given me a few ideas on how to go about building a desk phone version/equivalent to the TT-MK1-A), along with a home-made video game controller (looks to be using standard Arcade components), a lantern stand and a very incomplete test-tube rack.... Huh
The goggles become a warning.
« Reply #14 on: February 20, 2010, 05:15:45 am »
The Spirit of St. Louis phone is spot on (defective ringer removed, that semi-coated wire winding out of the top is connected to a large bellringer once found in a German phone from 1971), the partially threaded brass thingies will become lantern hooks, the arcade controller is made from Japanese standard parts, and the test tube rack is very incomplete and might stay that way until I can finally procure silver solder. Can't really weld it with my puny tools.
Bad Behavior has blocked 1423 access attempts in the last 7 days.
Page created in 0.319 seconds with 19 queries.
