February 09, 2012, 05:45:15 pm *
Author Topic: Zeppelin Cane!  (Read 1383 times)
mr_Apricot
will_duffield
« on: November 06, 2009, 10:02:11 pm »
I made this cane out of an ancient toy zeppelin that i found in Philadelphia, and a banister upright. The zeppelin was originally covered in rust, it once had a nickel covering but water got under it at one point so it had to be stripped down with pickle acid and steel wool. After that i painted it and sealed it. The banister i sanded and painted, i think the whole thing came out rather well, but what do you all think?
Eddie Chaos
« Reply #1 on: November 06, 2009, 10:07:34 pm »
Good show sir, what may i ask is at the other end of your splendid cane?
Mr. Hatchett
Unnaturalist
« Reply #2 on: November 06, 2009, 10:11:36 pm »
I think it'll go really well with the rest of your kit.  The white bit at the middle of the shaft is a nice touch - it holds the shaft and the handle together visually.
mr_Apricot
will_duffield
« Reply #3 on: November 06, 2009, 10:13:49 pm »
I have wrapped the other end in sheet brass and fixed it in place with three small screws, it should extend the life of the cane considerably.
markf
« Reply #4 on: November 07, 2009, 04:09:26 pm »
That is a great cane, very original and well executed.  markf
alsih2o
« Reply #5 on: November 07, 2009, 04:13:16 pm »
 I like it a lot. I agree that the mid-shaft accent brings the whole thing together. How is the weight? With only a picture I can imagine the Zepeling being prohibitively heavy OR being a perfect balancer.
Mr Peter Harrow, Esq
« Reply #6 on: November 07, 2009, 04:18:21 pm »
Nice, I would have tried brass plating with my caswell kit, something to consider when the paint job comes up for renewal, especially if steel.
You can get brass walking stick ferrules (the bit which protects the wood from wear) which polish up nicely, again somethingto consider when wear sets in.
Otherwiseif it ain't broke, don't fix it.
mr_Apricot
will_duffield
« Reply #7 on: November 09, 2009, 09:06:50 pm »
i believe it is some kind of iron, it was plated in nickle originally but water had gotten under than and rusted
« Reply #8 on: November 09, 2009, 11:18:50 pm »
Should be possible to replate then, iron or steel is optimal for such plating.
lilibat
gamer geek goth girl
lilibat
« Reply #9 on: November 10, 2009, 07:06:17 am »
Neat!
« Reply #10 on: November 10, 2009, 09:01:01 am »
Could plate silver or gold with the Caswell kits, as well as brass, so plenty of options for the future when the issue of repaint comes up.
You can prolong the current paint jobs life by using a good clear varnish, and you can aways dress up the shaft of the cane by painting/carving.
Lord Jeffreys
« Reply #11 on: November 10, 2009, 02:54:53 pm »
Fantastic! What a great idea!
Bad Behavior has blocked 1424 access attempts in the last 7 days.
Page created in 0.167 seconds with 19 queries.
