July 20, 2018, 12:24:26 pm *
Author Topic: Clock dissection help?  (Read 1190 times)
LostHorizons
« on: June 14, 2009, 06:02:03 pm »
I have acquired defunct clock that is more scrap metal than anything else. I'm trying to salvage the gears within, the largest of which measures about 2.5 in (6-7 cm). These are connected to the springs. The rest of the gears are connected to shafts which I neither want nor have use for.
How can I remove the gears from the shafts/springs without hurting the gears?
I have access to: soldering implements, hacksaw, power drill and bits, hammers, screwdrivers, socket wrenches, monkey wrenches, wire cutters, bolt cutters, pliers of many persuasions, and files.
In addition, can anyone recommend a degreaser?
Ours was a city of lost horizons and towering stories... A city of front and back, a city of light and shadow.
-MirrorMask
Server Monk
« Reply #1 on: June 15, 2009, 02:05:19 am »
Word of advice first : make SURE the main spring is UNWOUND! - there is quite a bit of energy locked up in a clock spring, pulling the clock apart with a wound up main spring is a good way to get a nasty surprise, and possibly an injury (it's happend to me before, I speak from experience...). Wink
The shafts on the gears can be tapped / pushed out - have a search of the forums, there's one or two threads that describe this.
For a degreaser, any petroleum based solvent will work (petrol (gas), white spirit (paint thinner / turps substitute), paraffin, WD40 etc.) To remove any left over traces of grease / oil, use soapy water or methylated spirit (methanol / camping stove fuel). Smiley
As for how to take it apart - it depends on how it's held together in the first place...  Wink
SS
[Server Prayer]
LostHorizons
« Reply #2 on: June 15, 2009, 09:23:21 pm »
Thanks very much. The advice on the springs came a bit too late; I gave myself a rather nasty shock when they popped free from the housings.  Roll Eyes I still have all of my fingers, so no harm done.
SimpleComplex
Head engineer aboard the Scorpionus.
« Reply #3 on: July 03, 2009, 07:49:07 am »
..i made an auto-rig that uses pliers in reverse to get the springs out..it never works well but it sure was fun making a robot.
"Rookie, who's arm is stuck in this gear?"
"That guys?" *rookie points at dead body missing arm"
"Correct, wait, there's really an arm in this gear?"
"Yea"
*rejoices*"I'm not crazy anymore!!"
Page created in 0.037 seconds with 17 queries.
