Doctor Frinkelstein
 United Kingdom
« on: January 11, 2009, 08:00:47 pm » |
Hello there! I'm a lurker that's finally decided to build my own Steampunk Watch. It's taken about nine months to collect all the pieces, (thank you eBay), but it's been a lot of fun. It's based on an old Smiths pocket watch from the 40's or 50's. Not exactly the right period but I like it!   I'm still tinkering with it. It may need some illumination... *EDIT*  I've continued tinkering and after fiddling around with the copper hour wheel washer, I've done away with it and fashioned a little bracket to hold it in place. I'm rather pleased with it! I've also forgone putting any numbers or markings on it, I just like the way it looks as it is. Still mentally designing illumination. Have you seen how small LED's are these days?
« Last Edit: June 05, 2009, 09:30:03 pm by Doctor Frinkelstein »
Prof. Albrecht Von Taggërt
« Reply #1 on: January 11, 2009, 10:55:09 pm » |
I really like that, it has that cobbled together look but is quite attractive! From what i can see the watch it's self is removable, which makes it even better!
Oh and Welcome the the forum!
Rowan of Rin
 Australia
~The Black Blood Alchemist~
« Reply #2 on: January 12, 2009, 05:39:22 am » |
Really very nice work, probably the nicest pocket watch conversion I have seen.
vt13013
« Reply #3 on: January 12, 2009, 01:10:12 pm » |
I'd love to accomplish something similar with a compass, though the means to attach it to the wristband would have to be reworked, since the compass in question has a hinged lid.
Cheers.
Doctor Frinkelstein
 United Kingdom
« Reply #4 on: January 12, 2009, 06:36:19 pm » |
It is removable, Professor. It still needs the occasional clean and oiling to keep it going. All part of the fun! I'd love to accomplish something similar with a compass, though the means to attach it to the wristband would have to be reworked, since the compass in question has a hinged lid.
Cheers.
VT, attaching it to the wristband was the hardest part until I found some little brass clothing tabhooks from a haberdashers. I hooked the main holder into that. I have a little brass sundial/compass that I'd like to wristify, I think I'm going to have the same problem you have! Thanks all for the kind words!
Angel
« Reply #5 on: January 16, 2009, 01:03:19 am » |
How does it fair on turning the watch upside down?
I've just disassembled an Ingersoll of mine (for good reason, of course) and when I removed the face, the middle cogwheel was loose. A method of keeping it down might be a good idea.
Also where did you source the brass wire? Was it expensive?
Cheers.
« Last Edit: January 16, 2009, 01:05:11 am by Angel »
"With a rifle, you can kill one man; but with a machine gun, you can make a whole army keep its head down." - Jeremy Clarkson Buns are obviously not designed for their aerodynamic properties.
 Canada
« Reply #6 on: January 16, 2009, 01:42:13 am » |
Its supposed to be a loose fit on the cannon pinion, the dial washer keeps it in place correctly under the dial.. (and dial washers are incredible easy to lose, if you're not careful...) If the watch was designed to have no dial (ie certain skeletonized movements), then there are other ways of ensuring the hour wheel stays put. Cheers Harold
« Last Edit: January 16, 2009, 01:54:09 am by HAC »
Dr Flonker
« Reply #7 on: January 16, 2009, 03:02:10 am » |
Personally, I like pocket watches better, but this one grows on ya...
Angel
« Reply #8 on: January 16, 2009, 01:16:37 pm » |
Its supposed to be a loose fit on the cannon pinion, the dial washer keeps it in place correctly under the dial.. (and dial washers are incredible easy to lose, if you're not careful...) If the watch was designed to have no dial (ie certain skeletonized movements), then there are other ways of ensuring the hour wheel stays put. Cheers Harold I understand it should be loose, to allow turning, but I meant loose along the length of the pinion. The only things keeping it in the watch are the hands.
 Canada
« Reply #9 on: January 16, 2009, 06:01:00 pm » |
Exactly.. thats what the dial and dial washer do...The dial washer looks like a small dished brass washer, not very big. The dished shape allows it to apply pressure on the hour wheel, once the dial is in place and seated properly.. If you remove the dial and dial washer, the hour wheel should lift off the pinion easily. Dial washers are needed to hold the hour wheel (and the attached hour hand) in place under the dial, so that it meshes properly with the minute wheel. If the dial washer is deformed or, scratched, the watch may run slowly or stop.
Cheers Harold
Doctor Frinkelstein
 United Kingdom
« Reply #10 on: January 16, 2009, 06:47:02 pm » |
I have nothing to add to what Harold has already written, you can see the copper dial washer on the photos. I learnt how important it was when I accidentally bent it, rebent it to what I thought was the correct shape and then had a few days of erratic running and frustration! I could not work out what the problem was.  I'm thinking of putting jewels, studs or something similar where the numbers should be. Any suggestions?
Doctor Frinkelstein
 United Kingdom
« Reply #11 on: January 16, 2009, 06:56:28 pm » |
Cheers.
The brass wire was from eBay, do a search for brass hobby and jewellery wire. It wasn't expensive. I also used narrow brass rods from a model steam railway shop, CJW Steam, also on eBay. They've got everything you could possibly want!
 Canada
« Reply #12 on: January 17, 2009, 12:24:40 am » |
I have nothing to add to what Harold has already written, you can see the copper dial washer on the photos. I learnt how important it was when I accidentally bent it, rebent it to what I thought was the correct shape and then had a few days of erratic running and frustration! I could not work out what the problem was.  I'm thinking of putting jewels, studs or something similar where the numbers should be. Any suggestions? How about small hexagonal bolt-heads, in a different metal? On dial-washers... yeah, you usually found out about those the hard way, I know I did  Cheers Harold
Doctor Frinkelstein
 United Kingdom
« Reply #13 on: January 19, 2009, 06:19:26 pm » |
I have nothing to add to what Harold has already written, you can see the copper dial washer on the photos. I learnt how important it was when I accidentally bent it, rebent it to what I thought was the correct shape and then had a few days of erratic running and frustration! I could not work out what the problem was.  I'm thinking of putting jewels, studs or something similar where the numbers should be. Any suggestions? How about small hexagonal bolt-heads, in a different metal? On dial-washers... yeah, you usually found out about those the hard way, I know I did  Cheers Harold Hmmmm, not a bad idea.... ta!
Doctor Frinkelstein
 United Kingdom
« Reply #14 on: June 07, 2009, 11:46:42 pm » |
Cheers.
Hi Angel, I've adjusted my watch with the addition of a little bracket to hold the hour cog in place. Photo at top. The dial washer was becoming a pain! Hope you sorted your problem out too!
 Canada
« Reply #15 on: June 07, 2009, 11:49:08 pm » |
Cheers.
Hi Angel, I've adjusted my watch with the addition of a little bracket to hold the hour cog in place. Photo at top. The dial washer was becoming a pain! Hope you sorted your problem out too! Actually, thats'a rather clever solution.. Nice one.. Cheers Harold
Doctor Frinkelstein
 United Kingdom
« Reply #16 on: June 07, 2009, 11:54:23 pm » |
Cheers.
Hi Angel, I've adjusted my watch with the addition of a little bracket to hold the hour cog in place. Photo at top. The dial washer was becoming a pain! Hope you sorted your problem out too! Actually, thats'a rather clever solution.. Nice one.. Cheers Harold Hi Harold, I am rather pleased with myself! More through luck than judgement, the bracket doesn't actually touch the wheel at all! I had to bend a kink in the hands to accommodate it but it works really well. Cheers! F.
Verner
« Reply #17 on: March 05, 2010, 05:48:38 pm » |
Beautiful work! I'd love to hear more about the construction process...
Ben Hudson, Esq.
« Reply #18 on: June 07, 2010, 10:00:26 am » |
Ditto, I've been thinking about something like this for quite some time.
Quod me non necat me confirmat Cappuccino?! I'll give you a cappuccino! Fellow of the Retrofuturist Society
« Reply #19 on: June 07, 2010, 01:31:10 pm » |
Still mentally designing illumination. Have you seen how small LED's are these days?  Have you considered tritium tubes?
Doctor Frinkelstein
 United Kingdom
« Reply #20 on: June 07, 2010, 02:43:15 pm » |
Still mentally designing illumination. Have you seen how small LED's are these days?  Have you considered tritium tubes? I hadn't, because I'd never heard of them. Quick Google, Wiki and eBay later, and I've got one on the way! 6mm by 1.5mm, should be perfect. Thanks for the tip! Once that's in, I'll see if I can do a dissection and rebuild, take some photos.
« Reply #21 on: June 10, 2010, 04:39:40 pm » |
They're becoming quite popular, espeically with the larger watches (the "tube" approach takes up more room then the old "paint" methods). Safer though. And more period-appropriate for Steampunk (although if you <really> want, I know a place selling an old set of radium based paint. They're in Canada, and can't ship it across the border though.)
« Reply #22 on: June 10, 2010, 05:42:39 pm » |
I should imagine building a watch from scratch is no mean feat so heartiest congrats on the end product. It's really nice. wristify, Made Up Word Alert!!
I say, Joe it's jolly frightening out here. Nonsense dear boy, you should be more like me. But look at you! You're shaking all over! Shaking? You silly goose! I'm just doing the Watusi
Captain Quinlin Hopkins
« Reply #23 on: June 10, 2010, 05:53:03 pm » |
Only 1200 miles away. Hmmm.. have to wait till I've a weekend off.
Sincerely, Captain Quinlin Hopkins (Hoppy) Do not ignore the freedoms of someone else, for eventually you will be someone else! DFW Steampunk Illumination Society
Doctor Frinkelstein
 United Kingdom
« Reply #24 on: June 10, 2010, 07:18:31 pm » |
I should imagine building a watch from scratch is no mean feat so heartiest congrats on the end product. It's really nice. wristify, Made Up Word Alert!!  Wristify? It's a perfectly cromulent word.
